Trunk light
Old Sep 16, 2012 | 09:54 PM
mitmaks's Avatar
mitmaks
Default Trunk light
So there was a battery drain which resulted in alarm going off in the middle of the night on our 96ES300
After investigation found out that trunk light would stay on, draining battery.
Is there a switch thats supposed to switch it on/off when trunk lid is shut? If so, where's it at. I've tried tracing wires but they go into package tray area and I didn't see any switches.
Old Sep 16, 2012 | 10:48 PM
I believe the switch is integrated into the power latch.
Old Sep 18, 2012 | 04:15 PM
mitmaks's Avatar
mitmaks
so how would I go about fixing this light on issue?
Old Sep 18, 2012 | 04:43 PM
Your latch looks like this.
You'll have to inspect it to see what is going on with the switch (the thing with the black wire on it)
Old Sep 18, 2012 | 05:04 PM
mitmaks's Avatar
mitmaks
ok, thanks!
Old Sep 21, 2012 | 06:15 PM
mitmaks's Avatar
mitmaks
So I took a look at it today and everything looks to be hooked up properly. When I pushed that switch manually light didn't go off, should I replace switch or how would I go about fixing it. I'm not very knowledgeable in electronics, need guidance
lsolesbee
May 16, 2017 02:15 PM
gotkiet
Jul 2, 2015 06:37 PM
416tt
Apr 18, 2015 10:21 PM
Caseyjones
Jul 26, 2014 10:48 PM
jpw
Apr 22, 2011 06:20 PM
