Fuel Gauge Incorrect
Old Jun 28, 2012 | 06:04 AM
Remired's Avatar
Remired
Default Fuel Gauge Incorrect
Ok so every-time put gas in my car the fuel guage doesn't go all the away up right away after a while it will go to the correct position but after that it will go down and then come up again. Also another thing at times the fuel light will come on and then go off. Is it suppose to stay on? Could you guys help me out and tell me whats wrong Thanks!
Old Jun 28, 2012 | 05:27 PM
Remired's Avatar
Remired
Can anyone help me out. It's a 1995 BTW
Old Jul 2, 2012 | 04:19 PM
Remired's Avatar
Remired
Ok so the car keeps cutting off more than ever i have to keep restart it i did some research and i found out the reason why fuel guage keeps fluctuating is because my fuel pump is broke and needs to be fix and that is also leading the car to continue to cut off. Can anyone please confirm this to be correct.
Old Jul 2, 2012 | 06:12 PM
Hayk's Avatar
Hayk
My gas needle takes a minute to reach the full level after a fill-up. I don't know if that's normal, but it does work just fine. The gas light goes on and off depending on the level of the car. It's a mechanical float, so the light can get brighter or dimmer depending on its position.
Old Jul 2, 2012 | 06:34 PM
PFB's Avatar
PFB
Your fuel pump has nothing to do with your fuel gauge. I would also be a bit suspicios of an intermittent fuel pump diagnosis. Get another opinion.
Are you sure that your fuel gauge suddenly indicates a lower amount? Apart from that anomality, it sound like your fuel gauge is working normally.
Phil
Old Jul 2, 2012 | 07:29 PM
imherenow's Avatar
imherenow
ya i too sometime have that..i think the mechanic said something to do with float (maybe)..but then he said he will have look inside and disassemble the tank and connections..i said naw right away..
altho this only happens once in a blue moon. so i am not worried
Old Jul 3, 2012 | 05:53 AM
Remired's Avatar
Remired
Phil
Yes i'm sure it takes a while to reach its normal but after while it goes down and i know that isn't normal. It continues to go up and down.
Old Jul 3, 2012 | 06:45 AM
PFB's Avatar
PFB
In that case, it could be one of several things, such as:
1) Defective or Dirty Sending Unit.
2) Defective Fuel Gauge.
3) Defective or Loose wiring including grounds.
4) Defective Fuel Tank, (loose internal buffles, allowing the fuel to splash around). In that case, it should not happened if you are not moving.
5) Dented Fuel Tank
Unless you can live with the problem, you will need to have someone diagnose and pinpoint the cause. It could be any of the above.
If its intermittent, I would wait until it gets worse. It will than be much easier and much less expensive to diagnose and repair.
Phil
Old Jul 3, 2012 | 08:35 PM
GS4_Fiend's Avatar
GS4_Fiend
Sounds like a bad float... to fix the problem you would need to buy a whole new fuel pump, cuz they dont sale just one part.
ATLs400
Aug 29, 2019 05:17 AM
thegr8one
Nov 16, 2010 01:22 PM
markgs4
May 28, 2006 11:49 AM
Grd4Spd
Feb 21, 2005 04:50 PM
aerodragon
Aug 24, 2004 06:33 AM
