All windows down with remote
Old Jun 1, 2010 | 01:57 PM
MikeP's Avatar
MikeP
Default All windows down with remote
Unless I'm going completely nuts, my 2010 ES350's unlock button on the remote worked like other Lexus I've owned. Holding the unlock button down will lower all windows and open the sunroof. I tried that procedure today because my car had been sitting in the sun and I wanted to let the hot air escape. Nothing happened when I held the unlock button down except the doors unlocked.
Last week I had the recall work done along with the brake override ECU upgrade. Could that have possibly altered the setting for the unlock button? I did check the user changeable options available on the 2010, but didn't see anything relating to the windows down function.
Old Jun 1, 2010 | 04:07 PM
Bakerman's Avatar
Bakerman
Had the same question. Looked it up in the owners manual. It appears the dealer has to set this option.
Old Jun 1, 2010 | 04:26 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Correct, it's an LPS (Lexus Personalized Setting) set by the dealer. The dealer should have given the OP a Sheet of all LPS settings when he picked up the car. The settings are usually changed by the dealer at the 1K mile mark for no charge.
Lou
Old Jun 1, 2010 | 05:35 PM
MikeP's Avatar
MikeP
Guys, thanks for your responses. That's the same info I received from my dealer. Remembering that I used that feature on my ES before was just another senior moment. Those moments seem to occur much too frequently. I'd better hide my driver's license so it doesn't get taken away.
Old Jun 2, 2010 | 04:08 AM
SteadyEddy's Avatar
SteadyEddy
From: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
Just tell them you forgot where you put it!!!!! And you'll give it to them when you find it.
provlima
13
Apr 13, 2017 03:46 AM
KevGS460ML
Jan 11, 2012 02:45 PM
TomLS
Jun 22, 2010 08:03 AM
kl323
May 22, 2010 05:43 PM
nMeOnE
Nov 20, 2009 04:07 PM
