Brake Light Bulb
Hey, one of my rear brake lights is out and I am wondering what kind of bulb do I buy to replace it? I have a 92 ES300
http://www.sylvania.com/ConsumerProd...RG-Results.htm
those are all the bulbs in your car and i believe it is 1157
sorry try this one http://www.sylvania.com/ConsumerProd...lacementGuide/
just put in your car make year and model
Just so you know, not all the bulbs that are listed on Sylvania.com are the right type for your car. I punched in my car info and bought the bulbs listed and realized they were not the correct type. Example for the trunk it states its a 194, the same for the courtesy door lights, but when I removed the trunk light, it was a fuse tube looking bulb. Another example is my license plate lights on Sylvania state 2825, but they look identical to a 194 bulb. So just be aware that their might be errors..........
DixonPai, where did you get your LED's for your car? I was able to convert some of my bulbs to LED's, but I couldnt find for my front corner lights/signal lights and everything on the rear tail lights (brake light, signal light, back up light and tail light itself) Thanks..............
https://www.clublexus.com/forums/es3...-96-es300.html
also I suggest you make use of the search tool you may find some other fun stuff you were not looking for.
but for my signal light I got it from V-LED They can provide you with every LED you can possibly need for your car
I cant help you on the tail ones because, I didnt mode any of them, but i doubt that sylvania is wrong with the tail bulbs, but I maybe wrong
Well I got most of my interior ones on ebay
gerbjones
Aug 31, 2005 12:12 AM
