1997 ES300 code:P0135 =(
Old Mar 10, 2008 | 09:26 PM
AlleyKat's Avatar
AlleyKat
Default 1997 ES300 code:P0135 =(
Heated 02 Sensor Bank 1,Sensor 1
So this code basically means the 02 sensor in the exhaust manifold.I changed it out but check engine didnt clear.The probable cause are:
1- 02 sensor defective
2- poor connection at oxygen sensor
3- check circuit fuse
Im sure its number 3.Were is that exactly?I also noticed the fuse to the clock and side mirrors went out again after only maybe 1-2 weeks on me replacing it.I guess there is something shorting it out.
Any help is appreciated.Thanks.
-Alex
Old Mar 10, 2008 | 09:28 PM
AlleyKat's Avatar
AlleyKat
damit i just found a thread that says bank 1 is actually an 02 sensor by the firewall.I guess I changed out the wrong one.I never knew there was an 02 back there.
Old Mar 10, 2008 | 09:51 PM
bestfromnw's Avatar
bestfromnw
haha i did the same thing today
Old Mar 10, 2008 | 11:01 PM
AlleyKat's Avatar
AlleyKat
Did you change it out already? Im gonna wait till the daytime to see how it is.I hope I still have the old 02 sensor I removed from the header.I guess I put in a new one for nothing.Maybe the rear one is the same as the new one?I can just reuse it.
Anyone have an idea why my mirror/clock fuse went out again?
Old Mar 11, 2008 | 01:42 AM
bestfromnw's Avatar
bestfromnw
i changed it out, and broke the old one by accident wile doing it
so i guess i cannot reuse it.... autozone here i come again
Old Mar 11, 2008 | 09:20 AM
AlleyKat's Avatar
AlleyKat
What route did you go to pull it out.Im about to go outside and look at it.Maybe I can get my gf to fit her little hand in there to get it.
Old Mar 11, 2008 | 03:35 PM
AlleyKat's Avatar
AlleyKat
Wow I cant find it
Old May 25, 2009 | 12:45 PM
tom8757's Avatar
tom8757
Default 97 oxygen sensor
I bought a new sensor, put it in the front and found out i should have changed the back one. I got a bank 1 sensor 1. So I took the original one I took out of the front and put it in the back.
I still get the check engine light. I disconected the battery, the I took out the EFI fuse. Both times the check engine light went out. It's when i went to restart it the check engine light came back on.
Do I need to buy a new sensor for the back? The old one worked on the front.
Help?????????
Old May 25, 2009 | 01:11 PM
GEORGE_JET's Avatar
GEORGE_JET
-Alex
The manual state to check the resistence of the heater (at the ecm, with the connector removed from the ecm) and then check the fuse. Before replacing the sensor.
tommy329
Nov 27, 2017 04:21 AM
Jae416ix
Mar 15, 2017 05:49 PM
JRMireles
Mar 10, 2017 12:29 AM
Chuckinnj
May 30, 2015 07:03 PM
DuneDain
Maintenance
Aug 15, 2012 09:31 PM
