having electrical problems
Old Sep 29, 2007 | 05:26 PM
Elite's Avatar
Elite
Question having electrical problems
this has happened three times in the last week. i go to start up my car, and i get 0 battery. all electrical stuff goes out; ignition, lights, door locks, everything. it's as if no battery is hooked up.
But once i disconnect and reconnect the negative terminal, i get full power and am able to start the car no problem. Is this just a terminal connector problem? b/c the (-) connector is pretty corroded from the failure of my last battery. i have a new battery only a month old
Old Sep 29, 2007 | 07:04 PM
esucaris1's Avatar
esucaris1
yes it sounds like you have a dirty terminal... You can use a baking soda and water mixture to clean the cable end along with a wire brush... myself I would take my new batery out to prevent accidental soda contamination of the cells... also there are felt anti corosion washers that you can get at any part store
lexixel
Aug 5, 2016 10:04 AM
arunp1783
Maintenance
26
Sep 9, 2005 09:50 AM
Taka
Jan 18, 2002 08:45 PM
retrodrive
Sep 25, 2001 10:10 PM
