starting problem, battery cable
lately, when I start the car, sometime all power is gone and I have to open the hood and touch the (+) battery cable connection, then power will be back. I tighten the connection but it will happen again.
does anyone have experience this problem?
Is it the alternator? or (+) battery cable..
any clue?
any clue?
Taka,
Clean the two posts with baking soda mix with water then tighten both post. Negative and positive. Always take the negative out first if you want to disconnect the bat., installation is reverse (negative last)
I had this problem as well, I ended up replacing the battery but make sure the cable is tightly attached to the battery. I found out the cables in our car comes loose over the period of time.
Peter~
Peter~
lexixel
Aug 5, 2016 10:04 AM
