They annoy me because at night when Im running around and I make quickstops, I like to turn off all the lights with the car running. I like discreet when Im parked at night.
In order to adjust your headlight, you can do so by using an 8mm socket wrench( I think) and it's right behind youre headlight one on the inside corner to adjust horizontal and the other between high and low beams to adjust vertical. turn the screws respectively and you should be able to determine which side does what. I think that's right, that's how it is on my second gen
