What went wrong??????
Old Sep 23, 2006 | 03:00 PM
itgrowsind's Avatar
itgrowsind
Default What went wrong??????
I had my spark plugs changed out today. I bought Denso, and no other engine work was done....but the weird thing is when I let off the gas the car feels like its going to shut off. It only does this when I let off the brakes at stops. When im driving this does not happen what could it be?
Old Sep 23, 2006 | 06:01 PM
itgrowsind's Avatar
itgrowsind
Wow so no one has come across this before?
Old Sep 23, 2006 | 06:15 PM
intrmsof2's Avatar
intrmsof2
check engine light illuminated?
Old Sep 23, 2006 | 06:35 PM
vin 78's Avatar
vin 78
Check the spark plug wires
Old Sep 23, 2006 | 07:45 PM
Tammy's Avatar
Tammy
Denso Iridiums ? Were they the exact same plugs as were removed?
Old Sep 23, 2006 | 08:44 PM
3rdelement's Avatar
3rdelement
check all vacuum lines, also check your plug wires. did you replace them or use the old ones? maybe one of the old ones discentegrated like mine did.
goood luck
Old Sep 23, 2006 | 11:03 PM
intrmsof2's Avatar
intrmsof2
It sounds like one of the coil packs just didn't get seated properly on the plug or, as mentioned, one of the wires has lost some of its conductivity through corosion of the wire or connector. Most of the above-mentioned faults should trigger a check engine light, including the one I suggested, but it is possible not to. Go back and check all your connections before you go spending more money.
Old Sep 25, 2006 | 03:06 AM
FwC's Avatar
FwC
I don't know much about this stuff but maybe spark plug gaps are off?
resharoo
Jul 21, 2015 09:49 AM
LDNN
Jun 22, 2012 05:03 AM
TLsc300
Aug 28, 2010 04:57 PM
baekpro
Jan 26, 2009 08:00 AM
samsc300
Nov 19, 2004 10:55 PM
