Remote start for ES330
Old Dec 4, 2005 | 08:52 AM
lovemov's Avatar
lovemov
Default Remote start for ES330
Is it possible to install remote start for ES330? Will Lexus dealer do this? If not, who usually has the service? I think it's useful for this cold weather...
It's better if it uses the original keys.
Thanks.
Old Dec 4, 2005 | 11:45 AM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
Thanks.
no the dealer probably wont install, and even if they wuld, you would get raped. go to a specialty shoop, alot fo car audio places do remots starters, especially fi they do alarms. a really good one will run $499-$699 installed, while an average one will run you $299. i would go with the average one unless you need like 2 miles of range. they arent average in reliability just features.
Old Dec 5, 2005 | 12:37 PM
05ES330's Avatar
05ES330
CL Folding 25,000
this was discuessed in another forum. i found that lxulink is in the process of making a kit for the ES330, but they are very pricey, but then again i think they are plug and play. DEI also makes a unviersal one. you retain your remote function and start your car with factory remote and it only costs 80 bucks. i planning on doing this mod after i lower my car
Old Dec 5, 2005 | 11:46 PM
YJC88's Avatar
YJC88
Luxury Motorworks did them for me and its preety good until today!
Old Dec 6, 2005 | 11:18 PM
05ES330's Avatar
05ES330
CL Folding 25,000
luxury motorworks has a working kit out for the ES330 now?
Old Dec 7, 2005 | 08:02 AM
YJC88's Avatar
YJC88
It was out since Summer last year, I used it for 20,000 miles now! Hehe
Old Dec 8, 2005 | 05:26 PM
lovemov's Avatar
lovemov
I have visited their website, I don't think they have one for ES330,
http://www.luxurymotorworks.com/luxl...mote_start.php
Are you sure you have ES330 model or use another instead? Thanks.
Old Dec 8, 2005 | 05:41 PM
lovemov's Avatar
lovemov
DEI does support ES330? Do you know if they have installation instruction in the kit for ES330? Thanks.
Old Dec 8, 2005 | 07:49 PM
YJC88's Avatar
YJC88
Well you might ask them through the phone, I got mine as LUXLINK, Luxury Motorworks
Old Dec 10, 2005 | 06:04 PM
05ES330's Avatar
05ES330
CL Folding 25,000
When I emailed LuxLink about a remote start for the ES they said they were working on one and would have one out by the end of the month, which was like in october i think. do you have the part number for the one you bought from luxlink? the DEI is not a plug and play kit. there are instructions. Remote start is almost like installing an alarm. its not that hard at all.
Old Nov 3, 2017 | 12:49 PM
mirekti's Avatar
mirekti
Hi there, I am digging this thread out from graveyard as I recently moved to Chicago area and...
...well, I'd really like to install, or let someone install remote starter on my 2005 ES330. Is this possible with my model, any suggestions?
Old Nov 5, 2017 | 01:57 AM
Ace20Six's Avatar
Ace20Six
You did some major digging here lol
Get a universal remote start/alarm combo. Or most sell just the remote start feature too if that is all you are looking for.
If you don’t have any experience I recommend you have a shop do it.
Here are a few of top brands I’d recommend.
Compustar
Idatastart
Fortin
and then any DEI product like viper, Clifford, python, avital, Astrostart etc.
Last I checked any of the DEI products will require separate/additional modules like a bypass for your chipped key. Compustar slightly older models have a built in slot for a bypass card that slides into the alarm/remote start module. Almost like a old Nintendo game boy. Their new line of remote starts/alarms that recently just dropped have this bypass feature built in so no additional units needed. Idatastart and fortin have bypass built into their units as well.
Your car might support 3x lock with the factory remote with one of the alarm brands above. You just hit lock 3 times with factory remote and the car will remote start. The range of this will be very short though, so however far away from your vehicle you are capable of locking or unlocking your doors will be about the same distance your remote start will work from. Which In my opinion is completely useless.
with the fortin and compustar units they do not come with remotes, you have to purchase those separately. So you get the option if you want
1way remote(you send a lock/unlock/remote start command and the remote just lights up telling you it’s been sent)
2way remotes(send a command, remote lights up, then lights up again to confirm for you that the command was received)
then you got higher end options for 2 way remotes with lcd screens so you can visually see if your doors are locked or unlocked or if the car is running.
Old Nov 5, 2017 | 03:13 AM
mirekti's Avatar
mirekti
Thanks for all the details. I went with Compustar and remote is 2-way Prime R3.
Works great!!!
There is one small bug which maybe can be fixed, need to talk to the installer. Wheb I remote start & stop the engine (very unlikely scenario) the lights will remain on (I always keep them in on position). Also hiting lock button two times doesn’t help either. With the Lexus key first press locks the car, the second one shuts the lights.
This will be a game changer for Chicago winters, but also hot summer days. I am very happy and hope I wont have any battery drainage issues.
Old Nov 15, 2017 | 02:42 PM
Power6's Avatar
Power6
RE: the lights, I think this is a "quirk" of the ES, I have a Viper starter in my 01 ES I installed myself long ago, I keep my light switch on "auto" and it has the same behavior you describe. Your installer probably can't do much about it.
I figured it is likely due to the way the remote starter operates the car. As you can imagine the remote start is in effect "simulating" a bunch of stuff, like putting in a key without having opened a door, powering the engine circuit but not the accessories when in start mode, so you have to appreciate that you might find some consequences that are unintended! When you start and stop the car, its as if you put the key in, started it, and then shut it down and removed the key without having opened the door! The Lexus is a bit clever compared to simpler cars of its day, like it keeps the headlights on and doesn't start the timer to turn them off until you close the last door, or the trunk. So shutting the engine off without actually exiting the car might be confusing those clever electronics.
The only solution I found to this was go out to the car...open the drivers door, close it, lock the car and the lights will then go out. Again it's not a typical scenario, so don't have to deal with it but once in a great while.
Old Oct 19, 2018 | 01:51 PM
ilkinandr's Avatar
ilkinandr
Hey,
Any of you guys can link the parts you purchased to install remote start? Also did you get this installed somewhere or did it yourself?
Works great!!!
indyberett
Mar 2, 2015 07:45 PM
integlikew
RX - 3rd Gen (2010-2015)
Jun 12, 2010 03:10 PM
hs4me
HS 250h Model (2010-2012)
Dec 30, 2009 07:03 PM
bucwhokey
Nov 1, 2008 05:38 PM
Lexguy026
Dec 6, 2007 10:57 AM
