2009 ES350 P0138 code
Old Mar 10, 2026 | 04:20 PM
HRHLexus's Avatar
HRHLexus
4th Gear
Default 2009 ES350 P0138 code
My 80,000 mile 09 ES350 has a random reoccurring P0138 code. I have checked all the wiring & voltages. I replaced the bank 1 sensor 2 along with 6 new coil packs (Genuine Lexus) and new plugs. I have what appears to be a minor skip under load on the highway (sometimes worse than others) but no codes for that. I'm leaning toward a dirty/bad injector but like I said there are no codes other than the P0138. Are the aftermarket new injectors any good? I have heard that the reconditioned DENSO injectors are not always a good choice. Anyone have any suggestions?
Old Mar 11, 2026 | 08:02 AM
June1978's Avatar
June1978
You've probably have a leaky injector, or an issue with the 02 sensor wiring harness
one user replaced the upstream sensor:
https://www.clublexus.com/forums/is-...h-voltage.html
Another changed the a/f ratio sensor:
https://www.clublexus.com/forums/es-...en-sensor.html
Old Mar 12, 2026 | 06:38 AM
ESh's Avatar
ESh
In almost every case of that code, the pre-cat O2 is the culprit.
Old Mar 12, 2026 | 03:17 PM
HRHLexus's Avatar
HRHLexus
4th Gear
Thank you very much for your reply. I see others have also replaced the A/F sensor to fix that code so I just ordered a new one. I'll post back once I install it and see if it solves my issue. Is it common for the A/F sensor to fail and not throw a code?
Old Mar 12, 2026 | 11:53 PM
ESh's Avatar
ESh
in this case they don’t fail, but they give false information
Old Mar 15, 2026 | 12:37 PM
HRHLexus's Avatar
HRHLexus
4th Gear
I installed the new A/F sensor today and took it for a nice long ride on the highway and around town, No CEL anymore. Thanks to all that helped on this.
Nospinzone
Feb 13, 2025 03:05 PM
jlf1997
Jun 5, 2024 07:06 AM
Kp1ck
Dec 25, 2019 09:16 AM
2gs300
Dec 13, 2014 07:30 AM
WainiacS
RX - 1st Gen (1999-2003)
Nov 28, 2011 07:04 AM
