Noisy ride
Old Jan 14, 2026 | 09:20 AM
lexygirl72's Avatar
lexygirl72
1st Gear
Default Noisy ride
Love my car but the road noise is very noisy. Anyone else have this issue?
Old Jan 15, 2026 | 04:55 AM
brucelee1's Avatar
brucelee1
Nope. Can you be more specific?
Tire noise?
Old Jan 15, 2026 | 05:05 AM
Kelby's Avatar
Kelby
Spend $2000 carefully with Resonix and it will be Rolls Royce quiet.
Old Jan 15, 2026 | 05:27 AM
kaigoss69's Avatar
kaigoss69
Tires.
Old Jan 15, 2026 | 05:38 AM
klazge's Avatar
klazge
honestly i had the same exact issue with my lexus and it drove me crazy because you expect these cars to be silent but the road noise was just way too much for me what ended up fixing it was getting rid of those stiff run-flat tires and switching over to a set of quiet-rated grand touring tires because the difference was literally night and day
i also noticed that these cars can be really sensitive to the type of pavement you're on so if you're hearing a lot of wind or road drone i'd definitely check your weatherstripping around the doors because sometimes they get a little dry and don't seal like they used to which lets all that noise bleed in you might even want to look at the wheel well liners to make sure nothing is loose or vibrating against the frame while you're at highway speeds
Old Jan 15, 2026 | 05:51 AM
st1800's Avatar
st1800
No, 14 ES. Quietest car I’ve owned. What type of noise are you hearing? What tires have you?
Old Jan 21, 2026 | 02:36 PM
uncle's Avatar
uncle
Noise can be hard to pinpoint. On my 2013 at about 85,000 miles, I heard a noise that no one else heard, origin to me was the right front. I thought it was tires and replaced the front two, same noise. I inspected everything, ruled out the right front axle assembly, shaft carrier bearing, no wheel wobble, etc. I decided it had to be the wheel bearing. I removed the assembly and could not see anything wrong with it, could not feel any grinding or restrictions, wobble or anything. I had a new bearing so because half of the work had been done, decided to reassemble using the new bearing. The old bearing after removal showed no sign of wear, bad seal, etc. After the reassembly, noise was gone. It was the bearing.
Old Jan 24, 2026 | 08:43 AM
st1800's Avatar
st1800
OP hasn’t been back since first post.
Old Mar 12, 2026 | 06:02 PM
ecstatic1's Avatar
ecstatic1
My ES350 is quiet, wife's RX350 is noisy. I feel like I hear a lot of road noise in the back.
Go figure.
Old Mar 13, 2026 | 08:54 AM
user 0598624089724's Avatar
user 0598624089724
Guest
Ionly hear tire noise from my 2016 es. Will be replacing soon since mine are on the way out. Looking for a good set that gives miles and cuts down on noise. I know that is hard due to softer quite tires wear out quickly and harder tires gives the milage but you give up on being quiet.
Old Mar 14, 2026 | 03:44 AM
brucelee1's Avatar
brucelee1
I am in the process or replacing my tires. Going with Michelin Primacy 4 summer touring tire. I live in FLA.
Old Mar 14, 2026 | 06:50 AM
user 0598624089724
Guest
Thanks will look into those.
Old Mar 14, 2026 | 11:18 PM
freshlysq's Avatar
freshlysq
8th Gear
Could be the hubs. I had to replace the front 2 due to the noise being loud other than that you didnt give us much to work with.
kenmtb
RX - 5th Gen (2023-present)
29
Oct 17, 2025 12:12 PM
manorth
19
Sep 22, 2025 07:36 AM
Mrd916
IS F (2008-2014)
16
Aug 29, 2014 09:53 PM
bbrowning1
Feb 11, 2014 03:23 PM
LXOGOOD
Wheels, Tires & Brakes Forum
Feb 13, 2002 06:23 AM
