2004 ES330 Shift cable Replacement 🤦🏻‍♂️
Old Jan 1, 2020 | 02:21 PM
TX4Runner's Avatar
TX4Runner
Default 2004 ES330 Shift cable Replacement 🤦🏻‍♂️
My Stepdaughters 04 ES330 had the Shift cable break and I have removed everything except the 2 10mm bolts under the Center Console/Dash. They are absolutely impossible to get to with a socket or even a 10mm open end wrench. Is there any way to remove them without taking out the whole A/C or Dash ?
Old Jan 1, 2020 | 02:38 PM
Even if you could turn it is there enough room to remove the bolt? Can you get at the other side or is that behind a layer in the firewall.
Old Jan 1, 2020 | 02:59 PM
TX4Runner's Avatar
TX4Runner
I have the clearance to remove it after it’s out, but because of the weird angle, not even an open end wrench can get to it. I purchased a $35 swivel 10mm open end wrench with a low profile and that didn’t work Either. I’m stumped on this one 🤷🏻‍♂️
Old Jan 1, 2020 | 03:13 PM
I'd take a 10mm closed end wrench and grind it down to be a slim as possible. Maybe heat and bent it for the best angle. Get creative.
Old Jan 1, 2020 | 06:24 PM
fortitude's Avatar
fortitude
Based on the manual, you do have to remove the AIR CONDITIONING RADIATOR ASSY. under the dash
Did the actual cable break or is the bushing end cap that connect to the floor shifter that broke and the cable pops off the floor shifter?
If so, have a look at this thread (s)
https://www.clublexus.com/forums/es-...uch-600-a.html
Old Jan 1, 2020 | 08:05 PM
TX4Runner's Avatar
TX4Runner
It completely broke off at the transmission point. It has to be replaced ...... Just my Luck 🤦🏻‍♂️😆
Old Jan 1, 2020 | 08:07 PM
TX4Runner's Avatar
TX4Runner
I have an extra one, Great idea ... I might try that 🤔.. Thanks !
JunRC
RC - 1st Gen (2015-present)
Dec 21, 2019 08:15 PM
BigEarl
Dec 14, 2017 07:52 PM
levinsoy
GX - 1st Gen (2003-2009)
Dec 16, 2016 10:55 AM
SC93
Sep 26, 2013 12:07 PM
sliva001
Nov 2, 2006 07:54 PM
