1995 windom lexus engine swap help needed
Old Jun 23, 2019 | 07:25 AM
Richiephil's Avatar
Richiephil
Question 1995 windom lexus engine swap help needed
Hi all am doing a engine swap in my 1995 windom lexus witch carries a 4VZ engine and transmission fwd am swaping it with a 2mz engine and transmission am almost complete with the electrical wiring but has a BIG PROBLEM the 4vz tranismission has a speedometer unit and the 2mz has none it came with a blank cap .Is there any way i can replace the cap with a speedometer unit ? if so witch one will work or what can i do to get this going .not getting a signal for the ecu to change the gears in the transmission .THANKS MUCH FOR YOUR TIME .
Old Jun 23, 2019 | 08:48 AM
What kind of cap? Can it be removed or is there no hole in the casting?
Old Jun 24, 2019 | 03:27 AM
Richiephil's Avatar
Richiephil
Default Speedometer cap
It’s a cap for a speedometer ,yes there is a hole for it as well but am trying to figure out witch one will work if any at all as that transmission did not came with one (speedometer unit ) .
Old Jun 24, 2019 | 09:56 AM
Maybe you can remove the cap or maybe there is no drive gear inside the transmission. Try looking up some parts diagrams on this site
http://www.japan-parts.eu/
Old Jul 7, 2019 | 03:55 PM
Richiephil's Avatar
Richiephil
Default Conversion
Hi all need some help with a 2MZ v6 front wheel drive what manual gear box can I replace my 2MZ transmission with ?
Old Jul 7, 2019 | 04:51 PM
E52, e53, e153
Old Jul 18, 2019 | 09:43 AM
Richiephil's Avatar
Richiephil
Default 2MZ transmission speed unit
Hey guys so I got the 2MZ transmission going by removing the cap and replacing it with a speedometer unit from the 1MZ transmission and it works fine thanks for the help 👍🏽
Old Jul 18, 2019 | 09:59 AM
Nice, and thanks for the update.
911LE
Aug 26, 2018 04:49 AM
trcarnut
Mar 24, 2013 05:17 PM
bangdangvn
Sep 24, 2011 10:33 PM
horent135
Jul 25, 2008 12:41 PM
