p1350 variable valve timing
Old Jan 3, 2018 | 08:22 PM
Carheart's Avatar
Carheart
Default p1350 variable valve timing
2002 es 300 102k. I got a p1350 code, variable valve timing. I replaced the VVT solenoid and check engine light is still on. Any suggestions? Cam Position sensor?
Old Jan 4, 2018 | 07:44 PM
Oro's Avatar
Oro
100k is VERY early for a solenoid failure. Did you clean the screens on each feed line?
what type of oil changed last when?
Old Jan 4, 2018 | 09:37 PM
Carheart's Avatar
Carheart
Changed the cam position sensor and vvt solenoid...lights still on. Changed oil about month and a half ago. Went to mobile full synthetic. I've heard of sludge build up in these 02's. ???
Old Jan 5, 2018 | 04:13 AM
HomerJay's Avatar
HomerJay
Please confirm- You erased the error code after the repair and it came back on?
Old Jan 5, 2018 | 07:51 AM
Oro's Avatar
Oro
ANY engine will form sludge if you don't change the oil frequently enough. The 02 engine is NOT known for being overly susceptible to that, so unless maintenance was very bad at some point, that should not be an issue.
I would repeat the initial two questions: Did you check and/or clean the feed line screens? What type of oil (weight)?
Old Jan 5, 2018 | 12:11 PM
Carheart's Avatar
Carheart
Default OEM fixed it
The screens were cleaned out yesterday and weren't very dirty. 5w30 mobile full synthetic. BUT I had gotten the cam position sensor from autozone...no good. Tried one from O'riellys...no bueno. I ordered a genuine lexus oem cam sensor, put it on and the check engine light went off. Factory part did the job so far. I've only driven about 25 miles so I'll keep my fingers crossed. Thanks for all the help. I'll re-post if it comes back on.
Old Jan 5, 2018 | 12:13 PM
Carheart's Avatar
Carheart
Thanks Oro
Old Jan 5, 2018 | 09:10 PM
Oro's Avatar
Oro
Glad you got it sorted. So frustrating when a new part fails from the get-go. I was asking my question as very thick or very thin oils can mess with this, but not what you are using by any stretch.
If you are in western WA, and already using M1, consider trying the M1 10w-30 HM. I have had tremendous success w/this oil over the years and miles. Fine for starting down to below 0F, and less additives and more "oil" in it than any 0w or 5w oil.
xWoke
IS - 1st Gen (2001-2005)
Aug 28, 2018 11:15 AM
TTslim
Aug 27, 2015 04:02 AM
buckeycat
Jul 10, 2015 10:25 PM
MrMark
Jun 12, 2014 07:40 PM
RXES300
RX - 1st Gen (1999-2003)
14
Jan 21, 2013 08:03 PM
