ES300 code 1350
Old Aug 22, 2015 | 01:17 PM
TTslim's Avatar
TTslim
Default ES300 code 1350
I have a 2002 es300 with code p1350 I have replaced the VVT on bank 2 front and cleaned the screens. The code won't go away what else should I check.
Thanks for your Help.
Tim
Old Aug 26, 2015 | 05:21 AM
TTslim's Avatar
TTslim
No idea what I should check next?
Old Aug 26, 2015 | 03:05 PM
ES300NZ's Avatar
ES300NZ
http://engine-codes.com/p1350_toyota.html
Possible causes
- Dirty or low engine oil
- Valve timing
- Oil control valve
- Variable Valve Timing controller assembly
- Engine Control Module (ECM)
What does this mean? What does this mean?
When is the code detected?
The P1350 code is triggered when the valve timing does not change from of current valve timing or the current valve timing is fixed.
So, check the base timing to make sure it's correct.
change the oil, filter, and remove the steel oil pan, clean that out carefully/fully. reseal with tube sealer type.
Old Aug 27, 2015 | 04:02 AM
TTslim's Avatar
TTslim
Thank you
The oil was changed less than a 1000 miles ago.
do know of a way to test the ECM?
Carheart
Jan 5, 2018 09:10 PM
LexusFan2
18
Sep 27, 2016 09:05 AM
buckeycat
Jul 10, 2015 10:25 PM
Mastana
Mar 27, 2015 03:45 PM
Stevius
Dec 27, 2014 12:19 PM
