05 ES330 Alternator went bad, after replacement, transmission slips into neutral
Hello Club Lexus members. I have a 2005 Lexus ES330 with 89,000 miles. The alternator went bad, and died as I was driving to the mechanic. After the alternator was replaced, I noticed the car slipping out of drive and into neutral. The issue became worse as I continued to drive. The mechanic I went to poked around, inspected the transmission for any wear. He noticed there was minimal metal shavings in the fluid, and that the transmission should be fine. I was thinking the issue had something to do with a surge to the Transmission Control Module/TCM when it died. Just towed the vehicle this morning to Lexus Woodfield in Schaumburg, IL and they told me there weren't any updates available and that the transmission needed replacement. $5500 + tax. I am almost positive its the TCM because the trans shifted perfectly fine prior to the alternator going bad, and shifted fine up until 10-15min into my drive after the alternator was replaced. Any help at this point would be more than helpful. My current plan is to take it to my original mechanic and have him replace the TCM to see if this fixes the issues.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
How did your alternator fail? A bad VR board can send damaging ac voltage through the system and damage some electronic parts.
Also, slipping from D to N is kinda vague - do you mean the gear shift moved, or the transmission just started slipping and you have no forward gears at all, or what? Certain things indicated mechanical fault, and others electronic.
Gill23 (08-04-17)
As long as your mechanic is really good. If not, find a talented one - they are out there.
From that description, someone very familiar with these transmissions can likely give a good answer. I'm not expert enough and I don't know a really good transmission person on this board who is (maybe there is). What I would do is take that 2nd description with a little more info and ask in the appropriate Camry forum at Toyotanation where more eyes could see it and hopefully an expert. Double check what year Camry V6s and possibly Avalons, etc. used this transmission and ask in that forum. My Transtec app says the Camry used this (U151E) from 04 to 12.
They would also want to know what happens if you start in 1st, 2nd, 3rd, etc. and what happens if you shift gears manually.
The description could be a bad solenoid in the AT. If it works sometimes, it is unlikely, but still possibly, the PCM (I do not believe these cars have a separate TCM; it is an integrated PCM AFAIK).
The car is not "slipping into neutral". It sounds more like the PCM is commanding the shift but it is failing to be done - either through damage to the clutch disks or because the solenoid is not effecting the shift. If the fluid is not burned/dark and bacon-y smelling, I would consider looking at the solenoids 1st. That is my semi-educated guess, and it is much cheaper and easier than swapping a PCM from what I understand. I have rebuilt transmissions and understand basic principals, but am not an expert.
I have been told, but never experienced, that failed alternator VRs can send AC ripple voltage that can damage electronics. I am unsure how often that really happens. I don't see it damaging a solenoid, though.
These are some thoughts to point you in the right direction; sorry I can't be more helpful.
It's an old thread but, if the trans shifts fine when cold and as it warms up, it begins to slip then most likely its a bad transmission. You could try changing the fluid and filter and it might work better-longer but, you need another trans. I use to spend the big money on trans rebuilds but, I don't/won't anymore. I would buy a used trans and they are around $350 to $500 and you could install yourself or have a mechanic do it. Total job with trans & mechanic install should be about a grand or less and the used trans usually come with a 6 month to a year warranty with unlimited mileage but, labor not covered. It's an option. good luck
Hi, haven’t been logged on in years. TCM was replaced with the alternator, also replaced the trans fluid. Issue improved slightly, but still has some hesitation under light throttle from 2-3. It’s been like this for years now but my mom drives the car now as she only commutes down the street for work. Super late reply but I guess this is something we’ve just dealt with and haven’t had any major issues since so we just deal with the sputter.
Hayk (09-07-21)
oldskewel
27
07-11-21 01:37 PM
ceddieb
09-09-18 12:51 PM
aaidenton
07-18-18 09:23 AM
