Tonight I just encountered an error with the cluster not dimming at night when you turn on the headlamps. I made sure my rheostat was not turned past the notch but up until the notch right before you click over.. Any suggestions as to what could be the problem, car has 115k miles on it
The other component that you should check is the light sensor located on top of the dash, right below the windshield. Shine a bright light on it for about 1min, and see if it makes a difference.
It's Sensitivity is adjustable, by turning it one way or the other.It could also be defective.it wouldn't hurt to tap it lightly a few times.
Mae sure nothing is blocking it.
I did shine a flashlight on it and sure enough they lights did go out. However Phil I never use the AUTO feature.. basically more of the problem is usually when you turn your lights on parking and headlights selection the cluster should dim along with the green box around D and when you turn off the lights everything goes back to bright.. the cluster and the box around D.
I'm not clear what you're saying. When you shine a light on the sensor and its dark outside, the dash light should brighten up to maximum, as it thinks its daytime.When its dark outside and you don't shine any light on the sensor, the dash panel lights should stay dim. During day light, the dash lights should stay bright.
Is that what's happening?
Everything I outlined works with the Auto feature of the lights turned ON. I never tried it in manual mode, so not sure what happens in that case.
Why are you not using the Auto feature?
Phil
On a normal operating cluster the panel is supposed to go dim for the driver to not get blinded when the headlamps are turned on by the operator manually.. then when you turn your lights back off the cluster is supposed to go to max brightness. do you follow? I like to turn the lights on when I feel as necessary not have the car do it for me
The part in the cluster that controls the electrolumincent lighting is not shown in detail in the wiring diagrams. However you can check the inputs and outputs going to that module.
According to the diagram (page 3 of the ES300 cluster schematic), there's a bulb check relay that is removable from the main-board on the instrument cluster. You could try swapping that to see if it makes a difference. You could also try disconnecting the rheostat to see if that makes a difference.
Interesting, which year model is this? On my 01 ES300 the light sensor has nothing to with the dash brightness. The gauges are dimmed when the headlights are on, but the brightness is set manually by a **** on the dash. I have the service manual, there is not any circuitry that would support that in this car. It would be cool, sometimes you turn the headlights on the daytime and you can't see the gauges well.
Here's the EWD for the rheostat.
When you put the car in drive and you have the lights on (NOT AUTO) the Cluster is supposed to dim along with the green box going around D for Drive, the lights for the radio and ac stay bright but the cluster is supposed to dim (speedometer, tachometer, engine temp, and fuel.) When I go to adjust the rheostat the cluster all the way down turning it all the way to the left the clusters brightness should be where it should (At dimmed level) but now I can't see the radio or ac cluster lights at all do you follow?!
