Hid fogs
Old Apr 21, 2012 | 06:11 PM
lexwill's Avatar
lexwill
Default Hid fogs
So I have ddm tuning 6 k h3's for my 99 es300 and I saudered the wires but I'm not getting power I just bought new lights all 4 of my ballasts are working tested them and all my fuses are good pulled them one by one and looked at them nothing is blown.. What's the issue please help ASAP!
Old Apr 21, 2012 | 09:12 PM
eyezack87's Avatar
eyezack87
Curious on why you soldered the wires since it should have worked w.out doing all that. Are you sure you soldered them correctly? As in + to + and - to - according to the wiring? I'm not too certain but I think HID kits are designed with polarity in mind...
Old Apr 21, 2012 | 09:18 PM
01LEXPL's Avatar
01LEXPL
^very much so...
Old Apr 21, 2012 | 09:53 PM
EEngineer's Avatar
EEngineer
never ever solder stuff on a car.
all factory wires are either plugged in or crimped.
Old Apr 21, 2012 | 10:04 PM
lexwill's Avatar
lexwill
Well they have worked but what happened was that the hot dissapation from my hids made it too hot then water got on my bulbs and then I bought new bulbs now won't work..I can fix the soldering but if that doesn't work what do you think it might be?
Old Apr 22, 2012 | 12:43 PM
01LEXPL's Avatar
01LEXPL
wouldn't be surprised if the heat from those bulbs [like i 'told you so' not too long ago] warmed up the gasket between the lens & housing, letting air in, making it condensate.
Another thing might be a fried wire harness - in which case you should be happy it only ****ed the fog wires & not the rest of the harness...
Old Apr 24, 2012 | 02:15 PM
eyezack87's Avatar
eyezack87
Another thing to keep in mind is the gauge of wire used during the solder process. Thats why I use the exact same when I do any soldering since its usually a last resort. To my knowledge, the ES fogs don't need any soldering done at all
Old Apr 24, 2012 | 05:40 PM
lexwill's Avatar
lexwill
I just did it so it was secure, that way I didn't have to undo everything to see if it was just a connection issue.. But i think it's the wiring harness I will check it this weekend and look more into the polarity..
Old Apr 25, 2012 | 09:47 AM
DanES300's Avatar
DanES300
They have reverse polarity. I had to connect negative to positive and positive to negative for them to work
Old Apr 25, 2012 | 04:21 PM
lexwill's Avatar
lexwill
Thanks Dan I'm gonna try that!!
Tnguyen9i6
Mar 1, 2015 08:34 PM
breakb
Lighting
23
Jul 3, 2008 01:53 PM
IEMaestro
Dec 24, 2007 01:27 PM
Davizzo
Oct 15, 2007 01:34 AM
CHAPIN33
Jan 2, 2007 01:34 AM
