3rd gen engine into 2nd gen possible?
Hey all!
I have a 1997 es300 that was damaged pretty extensively in the middle of the front bumper which destroyed the subframe, radiator, condenser, etc....
There is a 1994 for sale in the area that has a bad motor. Well, my motor and transmission are perfectly fine. I was wondering if it is possible to straight swap my good engine into the previous generation body without any modification.
Thanks all in advance!
Yup, it can be done without much issue. You'll just need to swap over all the sensors, wiring, and accessories from the '94 engine to the '97.
'94 WAS a 1 year only block though, so there are some very mild differences. BUT, it will not make a difference for the swap. You'll just notice a few differences on the block when you swap everything is all.
95-98 ES300 had the same shortblock. My friend has a '94 and swapped a '95 engine into his car, so that is how I know the minor difference in the block.
I;m not 100% sure on weather or not the tranny is the same though. BUT if the tranny on the '94 is fine, use that one with the '97 engine.
AGD3000
Jun 22, 2012 02:18 PM
