Head gasket failure
Im new here, i am now seeing that this head gasket problem is common with the CT. I just got a quote from Lexus at $4700 dollars to repair at only 157k miles...
This is crazy, why is there not a recall on this? I dont understand, I had NO CLUE this car had issues like this. In fact, I was told this car is typically good up to 400k miles.
Im beside myself with this issue. Even Lexus service says, "We are seeing a lot of this with this model with high mileage." Its not that high, its 157k.... seriously.
2ZR-FXE is unfortunately prone to oil burning and blown head gaskets. EGR system is also trouble prone.
youtube.com/watch?v=XOEMRHZl0aU
There is at least one TSB on this
https://www.toyoheadquarters.com/thr...-0168-16.2406/
Yeah, it's unfortunate. But hey, $4700 isn't a bad price, given that it's the dealer.
If you haven't looked into EGR valve and EGR cooler cleaning/servicing (the dealer doesn't do this, it's mainly a DIY thing), then do-so going forth if you decide to get this fixed. Every 40-60k miles should be a reasonable interval.
Just got a quote from a dealership of 7300. for fixing the head gasket at my CT200h. It has less than 60,000miles mostly sits in a garage. I am beyond myself. Can't believe but all started al of a sudden couple of days ago after an almost routine work at local service. Could it be that unqualified staff could tampered with my car deliberately or by accident causing a wild shacking and scraping while driving the car. Before that visit all was very fine, exceptionally good running machine.
I cleaned mines at about 70k and it was dirty but not clogged, so at 60k HG issue seems unusual. To keep it optimal might be a 50-70k interval cleaning. Wondering if using cheap gas vs Top Tier gas might make a difference?
maximusgx
GX - 2nd Gen (2010-2023)
46
Sep 9, 2024 04:20 PM
