CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
Sale TOMS and Project Mu NS-C / PS Brake Pads IN STOCK for IS F
Old Feb 17, 2021 | 04:37 PM
ModInJapan's Avatar
ModInJapan
Lexus Enthusiasts
Default TOMS and Project Mu NS-C / PS Brake Pads IN STOCK for IS F
PROJECT MU TYPE NS-C FRONT/REAR BRAKE PAD SET FOR LEXUS IS F LOW DUST / LOW NOISE / IMPROVED STOPPING
(STREET DRIVING WITH OCCASIONAL SPIRITED DRIVING)
  • Project Mu Type NS-C is the newest updated friction material building on the successes of the Type NS pad
  • Key Characteristics: Focused on low brake noise and low brake dust with a stronger braking force than OEM
  • Application: Street with occasional spirited driving that wants to keep their wheels clean
  • Material: Copper Free material for an environmentally responsible pad
  • Fade Resistance: A slot is manufactured in all Project-Mu pads to offer the gases an escape route.
  • Noise Suppression: A chamfer on the leading edge of the friction material to reduce unpleasant noise for low noise operation
  • Heat Treatment: Project Mu brake pads are subjected to heat treatment as part of the manufacturing process. This process 'burns out' unwanted materials in advance, reducing the gases that can cause fade. As a result, Project-Mu brake pads only need light 'bedding in' to match the pad to your rotor surface.
  • Ultra Durability: Brake pads are subjected to huge pressure from caliper pistons in unequal proportions across the pad. Brake pads must remain flat to offer optimal performance so Project-Mu use only the highest grade quality steel at the correct thickness to ensure this stability. Project-Mu pads are up to 20% stronger than some competitors.
  • Material Copper free
  • Applicable Rotor Temperature 0~400℃
  • Friction Coefficient 0.34~0.38μ
Front: https://www.modinjapan.com/project-m...mu-psf160.html
Rear: https://www.modinjapan.com/project-m...mu-psr106.html
PROJECT MU JAPAN TYPE PS STREET FRONT/REAR BRAKE PADS FOR LEXUS IS F LOW BRAKE DUST / LOW BRAKE NOISE - PMU-PPF160
(STREET DRIVING WITH OCCASIONAL TRACKING)
  • Key Characteristics: low brake noise and low brake dust with a stronger braking force than OEM
  • Great for daily driver that is a weekend track warrior
  • Project Mu brake pads are subjected to heat treatment as part of the manufacturing process. This process 'burns out' unwanted materials in advance, reducing the gases that can cause fade. As a result, Project-Mu brake pads only need light 'bedding in' to match the pad to your rotor surface.
  • Brake pads are subjected to huge pressure from caliper pistons in unequal proportions across the pad. Brake pads must remain flat to offer optimal performance so Project-Mu use only the highest grade quality steel at the correct thickness to ensure this stability. Project-Mu pads are up to 20% stronger than some competitors.
  • Material Non Steel Applicable Rotor Temperature 0~500℃ Friction Coefficient 0.38~0.45μ
TOMS RACING JAPAN "PERFORMER" FRONT/REAR BRAKE PAD SET FOR LEXUS IS F - 0449B-TW705
(STREET DRIVING BUT EMPHASIS ON TRACK PERFORMANCE)
  • TOM'S Racing Brake Pad Performer (Front)
  • Think of these pads as OEM+ with as they are well-balanced and improved performance over OEM genuine brake pads
  • Characteristics:
  • Low Brake Dust
  • Low Noise
  • Improved Braking Performance over OEM
  • Brake Rotor Temperature Rating: ~600C
  • Application: Lexus IS F Front Brakes
Front: https://www.modinjapan.com/toms-raci...49b-tw706.html
Rear: https://www.modinjapan.com/toms-raci...49b-tw706.html
To purchase and to learn more:
https://www.modinjapan.com/hks-super...023-at001.html
For Inquiries Text Us: 657-229-0050
For a formal quotes and information fill out this form: www.modinjapan.com/quote
__________________
1440 E Cedars St.
Ontario, CA 91761
WEEKLY specials PM me
Web: www.ModInJapan.com
Email: info@modinjapan.com
Toll Free: 866 599-5227
Local: 909 259-5117
Quick Quotes and Stock Checks, Send us a Text Message!
Text Here: 1-657-229-0050
k3nmasters
LX - 3rd Gen (2008-2021)
Jan 2, 2023 09:00 AM
LexUhs65
Oct 29, 2020 01:04 PM
SpeedFreaksUSA
125
Mar 18, 2020 05:28 PM
KevinGS
Suspension and Brakes
Aug 30, 2006 02:44 PM
LasVegasGS
Maintenance
May 17, 2005 11:53 AM
