Front Brakes Squeaking
I have a 2015 Lexus GS350 F Sport and recently replaced aftermarket front rotors and ceramic pads. After the first week, it is squeaking noise like crazy, squeaking happens every I apply on brake, and louder as the car slows down until stop. I changed to semi metallic pads but won't stop the squeaking. I stopped by Lexus dealership for advice and of course, they told me to buy the Lexus pads. I bought these pads and installed them on the same day, but did not stop the squeaking. Lexus then told me to buy the anti-squeak pads and did not stop the squeaking as well. Lexus now requests me to bring my car into Lexus shop for installing the Lexus rotors for $800. So far, I have 3 different types of aftermarket rotors, 4 different types of pads included ceramic, semi metallic, regular Lexus pads, and anti-squeak, but still could not eliminate the freaking squeal. I filled complaints to Lexus Head Quarter and hoping that they will take this issue into consideration and make it as a "case study" to improve it and make Lexus products better. However, they did not hesitate to told me that my Lexus is not covered by warranty and this is final. Anxious to hear some feedbacks from the club members..
Did you break in the aftermarket pads/rotors from your first brake job-properly? Replacement pads/rotors have to be treated like new brakes (which they are) for the first 500-1000 miles, depending on how much you use them. That means no heavy use or panic-stops (except if necessary to avoid an accident) for the break-in-period.
Also, just out of curiosity, why did you not use Lexus-brand parts to start with? The chances of having the problems that you mention are usually (but not always) a lot less with factory-parts.
Sometimes bedding can help and sometimes its just the combination of the pad and rotor that cause a squeal. Considering you tried multiple combinations, the third option is less likely but I've had situations where I've used three different pads and the fourth didnt squeal.
That said, plenty of OEM brakes have squeaking problems. There are even recalls/bulletins issued for this. I had brake squeak issues with my IS-F, and had good luck switching to the Project Mu pads.
Lexus parts are not one off magic. The same folks who make the aftermarket pads are the same contract mfgs for Toyota/Lexus. Line up the numbers and mfgs and you should be as close to OE as possible. I`m betting something with the install or hardware.
