BUICK 3800: The best engine EVER!
They're not comparable engines. DOHC V8 vs pushrod V6...
3800 may not be "best engine ever" but it sure as hell deserves some respect.
Loads of low end torque made them great for driving on American roads. They lasted well into 200k if taken care of.
3800s felt more powerful than they actually were, and an S/C one would give any UZ V8-powered LS a run for its money in a race.
3800 was light years better/faster/more reliable than any pushrod V6 from Ford or Chrysler, and better than most of their OHC V6s as well. It was better than most of GMs own OHC V6s, lol.
I read this R&T article a few months back where they're praising the old 3800 (and dissing new turbo motors) from a 1989 Oldsmobile they got a hold of.
https://www.roadandtrack.com/car-cul...rtrJQ1iU5h0cqM
"On the move, the Touring Sedan exhibits a torquey authority from the low-tech 3800 Series V6, combined with silent, seamless automatic shifts. It's more than fast enough to keep up with modern traffic, and it can return economy-car mileage numbers when driven carefully. There has been a lot of effort expended in the past ten years to make the current crop of turbo-four-bangers work as well in daily driving as this 31-year-old powertrain does, and most of that effort has been unfulfilling."
That being said, the original 1UZ was a terrible engine. It was smooth, but it was a clusterpluck of of vacuum and coolant lines, developed all kinds of leaks, had issues with coils, mafs, ecus, and was ridiculously difficult to work on. It was also terribly underpowered and returned awful gas mileage. The only thing it had going for it is that it was a non interference engine. Later revisions improved some, and when it became the 3UZ it was one of the best if not the best engines from every perspective.
I'd look at three criteria, in order of importance: (a) reliability, (b) efficiency, and (c) output per unit of weight.
Under "reliability," I'd have to say that I'm happy with my 3.5L Toyota V6 in my RX450h, though I don't have that much of a history with the engine. But reviews are very positive. Before this engine, I drove a Mercury Mountaineer with a 302 V8 for many years with never an issue until the very end.
As for "efficiency" I'd have to say that an Atkinson-style engine probably represents the pinnacle as measured by specific fuel consumption. The RX450h V6 is such an engine.
Finally, as for output, I really have no idea which engine is tops here, but it sure ain't the Atkinson engine, which sacrifices HP for efficiency in for form of a high expansion ratio. And I don't care about the actual HP figure, since one can simply build a bigger or smaller engine for the job.
I also don't care about DOHC versus pushrods. I'd say in general pushrods make for a more compact package while DOHC makes for more HP via increased redline.
As it turned out, my venerable 302 V8 in the Mountaineer began leaking coolant. Turned out not to be a simple fix--the timing chain cover bolts passed through the water jacket before anchoring in the engine block, and over time the threads would corrode. Ford and others said the only way to replace them was to pull the engine/trans partly out of the bay. Looking at $3K+!!! With other issues starting to appear (non-powertrain related) it was time to go to Truck Heaven..
Is that really true? I figure that all those fancy technologies will just break
But pretty much can be said about any Japanese NA 6 cylinder from that era - they were reliable, efficient and with less displacement usually had less low end but a lot more top end than the 3800. I'd take any of these 90ies/00s V6 or better yet 2JZ or BMW I6 engines over the current turbo 4s.
And yes, I agree. I would take almost any old 6 cylinder over these awful 2.0ts. I'd drive a late-model 3800 in a second over one.
What six cylinder Japanese engine was there in 1989 for sedans other than the VG V-6 in the Maxima (which was a pretty good engine too)? Cressida? Both solid motors but gutless next to a 3800.
Starting in the mid 90ies most Japanese V6 engines had more HP than the 3800, despite still being smaller displacement, and by 2000's smaller NA Japanese V6 engines were making more power and torque than even the supercharged 3800. It was certainly time to retire the 3800 which just couldn't compete in the late 2000s anymore.
That being said, at the time Toyota's 3.0 NA 2JZ was really the sweet spot with balanced 225hp/225tq output, but it did come at a premium.
Numbers on paper were solid, but on pavement it failed to deliver. I owned the original LS400 with the 1UZ, and a GS430 with the 3UZ - which was basically an improved 1UZ. The 1UZ was Toyotas first V8 engine, and it did have a number of issues. By the time they ironed them out and made various tweaks during that decade, and it transitioned into the 3UZ it was barely recognizable.
Thats because most people sang praises to the 1UZ when it was new. Once it got some miles under its belt, it was a royal pain in the *** to work on, one of the worst. I spent a good chunk of my time wrenching on it, and I developed a special hate for it. I've also worked on the 3UZ quite a lot, and what an improvement.
The 1UZ-FE is widely accepted to be an excellent engine lol, FAA rated for aviation use, won many awards. To call it "terrible" is just ridiculous. Yes they had some early things that were rectified, but the LS400 would not be regarded as one of if not the most reliable cars ever made if its engine was "terrible" and "riddled with problems"
Folks in the LS400 forum who's cars are now 30 years old disagree. You're in the extreme minority with this opinion.
My uncle gave my grandmother his 88 Pontiac Bonneville with the 3800 engine and it was very surprisingly quick up to about 60 or 70, then it lost just about all its ommph. I easily beat Mustangs and Camaro's with it all the time and it was the non supercharged engine, it was smooth and powerful up to about 60mph. It was odd because it was quicker, felt quicker then my uncle's 94 Lesabre and 96 Grand Prix even though they were newer, they both used the same basic engine, all those cars had problems though, build quality was not very good. Looking at its specs it probably felt a lot quicker then it was because the suspension was so floaty and steering so loose, it was nowhere near as quick as my GS430 which I used to shock passengers how quick it was.
