Aftermarket lug/wheel question
Old Oct 19, 2015 | 05:23 AM
newToIs250's Avatar
newToIs250
Default Aftermarket lug/wheel question
Hello all
This is a general question
Regarding aftermarket lugs and wheels, do you guys change your own wheels (summer/winters) or do you let the mechanic shop do it using his gun?
Do you use a torque wrench ?
thanks in advance
Old Oct 19, 2015 | 05:41 AM
4TehNguyen's Avatar
4TehNguyen
highly recommended to use a torque wrench otherwise you have no idea how much you have tightened it. Usually people overtighten it when they dont have a wrench.
Old Oct 19, 2015 | 05:59 AM
newToIs250's Avatar
newToIs250
Thank you for your reply
Yes regarding the torque wrench
Regarding aftermarket lugs and wheels :
Do you change the wheels yourself or do you let the dealer/mechanic do it,
Thanks
Old Oct 19, 2015 | 06:25 AM
evident's Avatar
evident
I have my winter set of rims and tires coming in today. they were mounted and balanced at tirerack (supposedly). I will be mounting them on my car myself, and resetting my TPMS with the ATEQ tool. if they are completely off balance or an issue arises I will take it to the shop. but at first, i'll be doing it on my own to avoid paying someone.
Old Oct 19, 2015 | 08:02 AM
GSteg's Avatar
GSteg
If I need to get tires replaced, I usually take them off the car and bring them to the shop, then reinstall when I get back home. Always with a torque wrench.
Old Oct 19, 2015 | 10:22 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I used to have to take it to a shop to get it done since I didn't have a good jack and my factory Lexus jacks were broken.
I've got a really strong jack now and I do it myself. Unfortunately I don't have a torque wrench though. I never let shops use impact guns on my lug nuts because they tighten the lug so much that I can't get them off and they scratch up my nice lug nuts.
Old Oct 19, 2015 | 01:38 PM
mmarshall's Avatar
Use a torque wrench whenever possible. Most wheels are correctly torqued at 75-85 ft-lbs., but see the Service Manual for that vehicle. Overtightening lug nuts (which often happens with impact-air-wrenches) can damage screw-threads and/or cause disc brake rotors to warp and cause a brake-pedal shimmy.
semar
Aug 27, 2015 12:49 PM
Jaysoo
Oct 5, 2014 05:16 PM
stvincent
Sep 26, 2008 06:14 AM
silversx
Jul 12, 2008 03:52 AM
lawman
Wheels, Tires & Brakes Forum
Jan 24, 2003 07:41 PM
