Build Threads Details on Club Lexus 3GS owner vehicles
Oceans13 GS460
Old Aug 11, 2021 | 06:57 PM
Oceans13's Avatar
Oceans13
Originally Posted by KevGS460ML
awesome. Looks like you’ve saves yourself a lot of downtime and maybe even expenses. Hopefully this car will last a long time to come!
Thanks Kev. I look forward to being done with all this and just enjoying the car.
Replaced the rear airbag crash sensor and re-installed the airbag module.
Also installed the Bluetooth streaming audio thing. Just gotta get the rear sub installed and i'll have nice jams finally.
I started the car and was half expecting the bags to deploy in my face, but the airbag light actually went away for the first time since I had the car. I guess those are fixed. I also fixed rattles in the dash speaker, doors, and sunroof rail.
And last but definitely not least, all that remains is to install the ABS. I asked a few local independent shops, but installation / programming and brake bleed requires TechStream, which they didn't have. I went to Lexus of North Miami to see about having them install it, but their customer service is horrible. Will try JM Lexus instead.
Old Aug 11, 2021 | 11:30 PM
petershen's Avatar
petershen
Great idea using the box wrench to hold the lock nut
Definitely beats cutting and welding the door support frame
I'll need to replace the ABS pump at some point, it's buzzing away more often than it should.
Seems like 44510-30300 is the new part number, did you buy it brand new? The old one that's in my car is 44510-30270
Old Aug 13, 2021 | 07:00 PM
Oceans13's Avatar
Oceans13
The BMS and a new brake fluid cap to help keep moisture out
Blown ML sub was shorting out the entire system
Got this 10" subwoofer. Peeled the rubber ring and put in on the bottom of the new sub. The wire connectors just screwed on.
sounds great
Old Aug 22, 2021 | 08:31 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
This is an incredible thread! You did some amazing work and your car looks great now.
Old Aug 27, 2021 | 05:32 AM
Oceans13's Avatar
Oceans13
Thank you Kira!
Quick update
Techstream customization. Turned off the steering wheel tilt when you start the car. Now it just stays down and extended. Turned off the DRLs. Turned off open locks when shifting to park. And turned off a bunch of chimes and buzzers and other noises. Car feels more luxurious now.
Old Aug 29, 2021 | 05:02 AM
Oceans13's Avatar
Oceans13
Hey Peter The lenses were for sale in the FB group, but I got the last set. However Id recommend buying the entire headlight than changing the lenses honestly.
Old Sep 1, 2021 | 05:06 PM
Oceans13's Avatar
Oceans13
Thanks Peter. Th e Morimotos are nice, and I liked the Infiniti Q45 projectors that some put in their GS300 headlights.
Update: Soundproofing and sway bar links..
Didnt get to it last time.
Drivers
Passangers
Rear
Threw the sway bar end links on
Sound deadening is pretty nice. Keeps the music inside and the road noise outside. The doors also feel more solid and less hollow and close nicer. Car feels overall more luxurious.
Old Sep 12, 2021 | 03:03 PM
Oceans13's Avatar
Oceans13
Installed new sway bar bushings. Quite a difference between the old and the new.
Noticed what appears to some dried coolant which had leaked down. Seems to be coming from the water pump. I ordered parts for a replacement. (Pump, therm, belt, pulley).
Ordered an all wood shifter from an RX, as I did with my GS300, but this one isnt fitting well. Going to figure out what to do with it.
Love the Japanese woodtrim.
Love the blackwood with my black carpets.
Another drain and fill.
Old Oct 20, 2021 | 07:15 AM
Oceans13's Avatar
Oceans13
Soundproofed the trunk / rear deck. The sub hits harder now.
Changed some hoses.
Cleaned the TB
Also the maf
Water pump / parts (old vs new)
Old Oct 27, 2021 | 06:28 AM
Oceans13's Avatar
Oceans13
Default Finally finished (for a long time hopefully)
Looked for a long time for a set of bigger Lexus oem wheels but decided to just leave the 18”s and get new tires. Ordered some sumitomo tires 🇯🇵 Had them Balanced, mounted, and alignment.
Old bridgestone rundlats from 2015.
Five months later. Finished with the 460. It runs drives sounds and looks amazing now
Old Oct 27, 2021 | 10:54 AM
petershen's Avatar
petershen
What a great journey and beautiful car
I wish the OEM fanblades are wider. The GS is under-tired from the factory... I found that by going to 275/35 makes the drive much more enjoyable, the car feels much more planted and alive.
Old Oct 29, 2021 | 01:13 PM
Oceans13's Avatar
Oceans13
Thanks guys.
Old Nov 12, 2021 | 12:19 PM
Bastrd6's Avatar
Bastrd6
What did you use on the outside amber marker?
Old Nov 14, 2021 | 08:58 PM
Oceans13's Avatar
Oceans13
those are inside the lenses, i just removed them while the housings were apart. Also the other chrome reflector pieces as well.
Old Nov 15, 2021 | 06:43 PM
Bastrd6's Avatar
Bastrd6
Ah good to know! Will probably do that when I have the new projectors tossed in.
Thanks!
