Build Threads Details on Club Lexus SC owner vehicles
AEM Wideband install questions
Old 06-22-18, 05:07 PM
IISevv
IISevv's Avatar
Default AEM Wideband install questions
I’m going NA-T on my 92 SC300 and have a couple questions about configuring the AEM Wideband to replace the narrowband output of the stock o2 sensors. Since the stock sensors are voltage based should I run the 0-5V output of the AEM to the o2 sensor input on the ecu, so it sees a signal and maintains values? I’m going to try to adjust AFR’s with a SAFC.
Old 06-23-18, 12:26 PM
scsexy
scsexy's Avatar
I would just run 2 o2 sensors, A stock one to make the car happy if your tryna to keep the stock ecu or a supra ecu like the tt ecu mod.
Thats what i have on my Na-t car 1 sensor going to both banks of the computers ecu and my wideband separate going to my gauge inside
Old 06-25-18, 06:23 AM
MLeopard
MLeopard's Avatar
Your AEM output can be set to emulate a narrowband (0-1V) O2 sensor. There is a rotary switch on the back of the gauge that changes what the sensor outputs. It will still display wideband values on the gauge. This should work to make the factory ECU happy.
Old 06-26-18, 06:23 AM
SupaDoopa
SupaDoopa's Avatar
You may have had better luck posting in the electrical support portion of the website. The answers above are pretty accurate, though. Just future reference.
Old 06-26-18, 08:53 AM
mrmj2u
mrmj2u's Avatar
Most down pipes have a provision for multiple O2 sensors. Any reason for wanting to run just one?
https://www.clublexus.com/forums/bui...l#post10215882
Old 06-26-18, 09:06 AM
IISevv
IISevv's Avatar
Stock, the only reason (as far as I know) they run 2 sensors is to compare data between banks of cylinders. 2 o2 sensors right after another with an aftermarket one-piece manifold shouldn’t provide the computer with any additional information.
Old 06-26-18, 09:14 AM
mrmj2u
mrmj2u's Avatar
So have you figured out which ECU you will use for your NA-t? If you are planning on running the GTE ECU, you only need one O2, it's pretty much the same with the stand alone's.
My setup, and most other turbo setups use 1 O2 sensor for the ECU and 1 for Wideband.
grumpi300
SC- 1st Gen (1992-2000)
02-03-15 08:09 PM
zerosix
Performance & Maintenance
03-21-10 08:32 AM
turbodremz
06-28-09 12:01 PM
boobstar
04-20-07 08:03 PM
Quick Reply: AEM Wideband install questions
