Build Threads Details on Club Lexus 2GS owner vehicles
Scottish Aristo. Large single, six speed, Wide arch
Old Sep 16, 2017 | 05:20 PM
kwalker705's Avatar
kwalker705
Default Scottish Aristo. Large single, six speed, Wide arch
Hey guys. Had the car since 2009. Long term love affair with the car thats seen me get familiar with every single nut and bolt on the car.
Started in 2009 with a almost stock low mileage car that'd only been in the UK for 2 years. Car was immaculate !! came with 5zigen lowering springs. Fujitsubo exhaust, HKS mushroom intake and 19" BBS LM's
Dyno figures indicated 330bhp at that point
Attached Thumbnails Scottish Aristo. Large single, six speed, Wide arch-buvg7twcgk-kgrhgoh-diejlllvv6nbko-tkbb9g-_12.jpg   Scottish Aristo. Large single, six speed, Wide arch-buvh-qg-2k-kgrhgoh-coejlllfz3lbko-w9v2wq-_12.jpg   Scottish Aristo. Large single, six speed, Wide arch-buvhc8w-wk-kgrhgoh-cuejlll1upibko-tw9b0-_12.jpg   Scottish Aristo. Large single, six speed, Wide arch-buvhidq-wk-kgrhgoh-cwejlll-g-hbko-v6k-fg-_12.jpg
Old Sep 16, 2017 | 05:25 PM
kwalker705's Avatar
kwalker705
2009 - 2010 I started making some small upgrades to the car.
Changed the suspension springs to HSD coilovers, Removed the cat, turned the boost up to 1.2bar and the car made 401bhp on the dyno
Took the car to an old airfield used for 1/4 mile racing from time to time. Not any startling times but managed to shock a few unsuspecting racers with how quick the aristo is.
Attached Thumbnails Scottish Aristo. Large single, six speed, Wide arch-photo0155.jpg   Scottish Aristo. Large single, six speed, Wide arch-250844_436787119676565_755791153_n.jpg
Old Sep 16, 2017 | 05:33 PM
kwalker705's Avatar
kwalker705
2011 things started getting a bit more serious.
Fitted Ksport 365mm front discs and 6 pot calipers. TOMS rear subframe braces were fitted and I for some unknown reason decided I was gonna buy a large Holset HX35 turbo and manifold.
Had the whole lot fitted up by late 2011 and got the car up and running.
Mapper was all booked up to set the car up using an AEM FIC. Unfortunately shortly before mapping another aristo using the FIC started to develop problems and the mapper decided he wouldn't use them anymore. Luckily for me the mapper is also the creator and owner of Syvecs. He suggested using the syvecs. That created a problem though. Back then syvecs wasn't capable of being used with the aristo's tiptronic transmission.
Attached Thumbnails Scottish Aristo. Large single, six speed, Wide arch-imag0180.jpg
Old Sep 16, 2017 | 05:36 PM
kwalker705's Avatar
kwalker705
So if syvecs couldnt be used with the tiptronic autobox there was only one solution....... a getrag 6 speed transmission swap
Due to work commitments and at the time my limited mechanical knowledge I contacted Paul at Sbody automotive about taking care of the box swap. He built his own nissan G35 falken drift car with a 2jz, 6 speed box, clamshell front and rear and 700+bhp. He was the ideal man for the job.
Attached Thumbnails Scottish Aristo. Large single, six speed, Wide arch-box-in.jpg   Scottish Aristo. Large single, six speed, Wide arch-img_4113.jpg   Scottish Aristo. Large single, six speed, Wide arch-226170_10150246884291442_614746441_7891985_7494802_n.jpg   Scottish Aristo. Large single, six speed, Wide arch-379971_10150390244026442_614746441_8704978_340319727_n.jpg
Old Sep 16, 2017 | 05:48 PM
kwalker705's Avatar
kwalker705
The HX35 turbo was going to be used and limited to 450bhp to save blowing the standard autobox to pieces.
After getting the 6 speed installed there was no need to limit the power figures. So the decision was made to remove the holset unit and change out for a garage whifbitz kit. Went for a twin 40mm wastegate setup , 3" downpipe and a Borgwarner S366 turbo.
While the car was away having the box done I decided to have them fit the turbo kit, an HKS timing belt, a driftworks oil cooler and filter relocation kit. Sbody automotive also got together with syvecs and installed the ECU and took care of the mapping. Vibratechnics developed some engine mounts for the car aswell
Car came back with 567bhp and 560ft/lbs of torque and was a hell of a handfull.
Next on the list was a Kazz LSD. Hated the Kazz unit and ended up changing to a Tomei unit which was much smoother and refined.
Attached Thumbnails Scottish Aristo. Large single, six speed, Wide arch-251430_10150246883366442_614746441_7891983_2551708_n.jpg   Scottish Aristo. Large single, six speed, Wide arch-turbo-mock-up.jpg   Scottish Aristo. Large single, six speed, Wide arch-250393_10150247497236442_614746441_7896813_588456_n.jpg   Scottish Aristo. Large single, six speed, Wide arch-img_4355.jpg
Old Sep 16, 2017 | 05:57 PM
kwalker705's Avatar
kwalker705
while driving the car home after the mapping was complete i managed to obliterate a large fox with the front bumper. Unfortunately the bumper came off a little worse for wear with the splitter breaking into 3 parts.
Managed to fibreglass it back together and had the whole front bumper painted.
Sent the BBS LMs away for refinishing at that point too.
Then managed to get a small feature in speedhunters. shame they used my "have a look at this pics" from my camera phone for the article instead of asking for better pics with my DSLR
http://www.speedhunters.com/2012/06/567hp_arist/
Attached Thumbnails Scottish Aristo. Large single, six speed, Wide arch-imag0176.jpg   Scottish Aristo. Large single, six speed, Wide arch-imag0233.jpg   Scottish Aristo. Large single, six speed, Wide arch-imag0236.jpg   Scottish Aristo. Large single, six speed, Wide arch-imag0258.jpg   Scottish Aristo. Large single, six speed, Wide arch-imag0219.jpg
Old Sep 16, 2017 | 05:58 PM
kwalker705's Avatar
kwalker705
Spec at this stage was
2jzgte
whifbitz turbo manifold
2x 40mm turbosmart wastegates
BW S366 turbo
3" downpipe
2.5" fujitsubo exhaust
K&N filter
HKS timing belt
whifbitz pulley set
driftworks oil cooler kit
2x walbro 255lph fuel pumps on custom hanger
aeromotive FPR
3" front mount intercooler and custom pipework
ID 1000cc injectors
whifbitz twin feed fuel rail
innovate closed loop lambda/wideband
Syvecs S6 ECU . 567bhp 560ft/lbs torque.
HSD coilovers
TOMS subframe brace kit
summit racing front strut brace
Ksport 365mm front brake conversion, 6 pot calipers
19"BBS LMs
Tomei LSD
EBC yellow stuff rear brake pads
Plenty more info to come on this ongoing saga of a project
Old Sep 18, 2017 | 12:29 PM
Hayce's Avatar
Hayce
Nice build, followed on Clubaristo until it died.
Old Sep 18, 2017 | 07:10 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Great Build..
Old Sep 19, 2017 | 12:29 AM
kwalker705's Avatar
kwalker705
Such a waste . Bags and bags of technical info/wiring diagrams etc etc all lost
Old Sep 20, 2017 | 07:57 AM
Mandrake's Avatar
Mandrake
I know. Its super hard to find info on these cars.
Nice car.
Old Feb 4, 2018 | 04:56 AM
Eggplantgs's Avatar
Eggplantgs
Great build !
SUPRAboy80
Nov 13, 2017 03:19 PM
S9JZS147
Build Threads
29
Dec 16, 2014 01:21 PM
CHASER4LIF
Lexus Vehicles Classifieds
Jan 24, 2013 05:40 PM
aido
Sep 1, 2006 12:45 PM
rcyo1
Apr 12, 2005 08:43 PM
