Build Threads Details on Club Lexus GSF owner vehicles
Liquid Platinum “Take 2”
Old Jan 16, 2018 | 09:57 AM
  #121
biggame's Avatar
biggame
Time to upgrade my suspension and wheels! Here is a sneak peek at what just arrived
Can you guess?
Old Jan 16, 2018 | 02:55 PM
  #122
finny76's Avatar
finny76
Looks like VOSSEN Wheels!
and maybe OHLINS shocks?
Old Jan 19, 2018 | 09:12 AM
  #123
biggame's Avatar
biggame
Decided to continue with Novel, and go with their suspension system...Quality product as expected!
Old Jan 19, 2018 | 10:00 AM
  #124
NotnFsport's Avatar
NotnFsport
What are the spring rates on the Novel coils?
Old Jan 19, 2018 | 10:22 AM
  #125
biggame's Avatar
biggame
Spring rate
Front 22kg / Rear22kg / Spring: Made by swift
Old Jan 19, 2018 | 12:31 PM
  #126
MileHIFcar's Avatar
MileHIFcar
Damn 22kg is that what's needed or recommended to control the weight of the GSF?
Old Jan 19, 2018 | 09:36 PM
  #127
lobuxracer's Avatar
lobuxracer
Tech Resource
Without knowing the motion ratios, the spring rates between two different platforms are meaningless. The suspension on the RC F and the GS F in the rear isn't coilover shock from the factory. They are configured like a 1950's Chevrolet with the springs and shocks completely divorced to save space for a bigger trunk. So comparing the spring rates you are used to seeing on the IS F makes no sense at all.
Old Jan 20, 2018 | 02:26 AM
  #128
MileHIFcar's Avatar
MileHIFcar
I'm guessing that the divorced set-up compromised handling? compared to a true coil over shock set-up from factory to make room for a bigger trunk. Could this be why they developed the TVD to compensate for the outdated rear set-up?
Old Jan 20, 2018 | 04:22 PM
  #129
lobuxracer's Avatar
lobuxracer
Tech Resource
No, it doesn't inherently compromise handling. It just makes the calculations for shocks and springs completely different and separate where they are not when the spring and shock are concentric. The biggest challenge with this kind of setup is finding springs in increments that are useful. Coilover suspensions have many standard sized springs in a wide range of rates where these custom OEM setups may not have any significant selection and you are forced to make due with what little there is available.
Old Jan 20, 2018 | 04:49 PM
  #130
MileHIFcar's Avatar
MileHIFcar
Interesting....thanks for the explantion!
Old Jan 23, 2018 | 08:08 AM
  #131
biggame's Avatar
biggame
Here is the Novel system next to the stock suspension for a visual comparison
  #132
biggame's Avatar
biggame
Installation was super easy as expected for the front, rear was a little more intense. Adjustment to lower or raise you Lexus is quick and easy!
Old Jan 23, 2018 | 08:09 AM
  #133
biggame's Avatar
biggame
Decided to go with Specialty Products for my rear camber needs. Well made quality product
Specialty Products adjustable camber arm side by side with the stock suspension upper arm
Old Jan 23, 2018 | 10:19 AM
  #134
finny76's Avatar
finny76
What was the weight of the stock suspension VS NOVEL?
Old Jan 23, 2018 | 10:51 AM
  #135
Stingraygt's Avatar
Stingraygt
Where did you source the steering wheel and shift **** from?
