I saw the group buy for these, but was literally two days too late...bummer! Very curious to see how they perform. Once you have installed them, please give an overview of your thoughts on the upgrade.
basically it gives you another "level" to put stuff instead of a mess of a deep hole
My before mess
After! my mess is hidden now
Where did it come from you ask?All I can say is Asia
This one pictured probably first one to make it over to State side.
Happy hunting for those that want one also
(Edit: You can purchase this tray all over now. Here's link to it for sale on ebay https://goo.gl/YhPmw5 )
The armrest tray is awsome man...thanks for the link too...I will definitely get one so i can use it to hold some coins lol.
Moving right along, we now are installing a Fsport Air Intake that I recently pieced together.
But there's a twist to it!
Before going out and purchasing the 3IS Fsport Air Intake kit, I noticed that the 2IS kit had a pipe with a Fsport emblem welded into place.
This got me curious and I wanted it more than the plain pipe that comes with the 3IS kit. So I did some research and found out that I can buy all the pieces individually in the kit as well as buy the 2IS pipe individually.
A small part of me was worried that it may not fit but since all the other 2IS intake out in the market transferred over to the 3IS just fine then it should in theory work. I priced it out purchasing it separately and it came close to purchasing a full 3IS kit. I went ahead and placed order for all the individually pieces.
Installing it......
And what do you know it works and looks awesome. Most people will miss this small detail but those that do spot it would appreciate it.
Here's a video of installing it....Subscribe to my youtube channel for more videos in the future like this! https://youtu.be/yK0BI7UgCj8
Here is are the individual part numbers if anyone else wants to do the same as i have. https://drive.google.com/file/d/0B-a...ew?usp=sharing
3IS parts numbers:
PTR03-53141-AA /// F-Sport Filter
PTR03-53141-AB /// F-Sport Air Box Upper
PTR03-53141-AC /// Bellows & Clamp Kit
PTR03-53141-AE /// Coupler & Clamp Kit
Here is part number for the actual one meant for the car as a full kit with all pieces together if you don't want to go all crazy like I did
PTR03-53141 http://amzn.to/2tCpNm1
Has some time finally to get the Ultimate Steering Response System (USRS) mounts onto the vehicle from RR Racing that has been sitting for a couple of weeks
Check out the video of the install I made. Hope you guys engine.
Check out the video of the install I made. Hope you guys engine. https://youtu.be/gaP3w4adGPU
What did you make the little nipple thing on the back of your license plate with? It looks like a kind of foam but how did you cut that shape or what material is it?
Thanks!
The little nipple thing is a hard black plastic rod the diameter of roughly as close to what i needed to fit into the grill holes. I then filed and sanded it down until it fit into the grill holes and then bore a hole into the middle and put a screw to hold it onto the factory License plate mount.
I can get some better pictures of all the separate piece if you wish as I can disassembly it to show you.
I also have a couple of these spare plastic rods as well (had to order in bulk just to use half of one). PM me and I will try to find them if you need some.
