Build Threads Details on Club Lexus LS460 owner vehicles
My 2007 Lexus LS 460 Build
Old Mar 16, 2026 | 06:51 PM
DJJD's Avatar
DJJD
Default My 2007 Lexus LS 460 Build
Hello, everyone. Welcome to my build thread.
I recently purchased a 2007 Lexus LS 460 from a dealership in Phoenix, Arizona. The car has 88,000 miles and is in great condition. Unfortunately, I purchased the car on a cool evening, so I was unaware that the dash (upper and lower) and center console suffered from the dreaded stickiness. I had the option of returning the car, but it is in such good condition otherwise, that I chose to keep it.
As I do with all my vehicles, I started with installing floor liners (WeatherTech, in this instance). I highly recommend these floor liners: they fit excellent and look great. I also had the windows tinted with 20% ceramic film.
Old Mar 17, 2026 | 01:59 PM
DJJD's Avatar
DJJD
When inspecting the car closer at home, I discovered that the water pump was leaking. Therefore, my first order of business was to replace the water pump. While working in that region of the engine, I decided to also replace the belt tensioner, idler pulleys, and serpentine belt. With the exception of the belt tensioner (Dayco) and serpentine belt (Gates), everything is genuine Toyota/Lexus.
Old Mar 17, 2026 | 02:00 PM
DJJD's Avatar
DJJD
Current project: replacing the sticky interior panels. I purchased the car in the evening after dusk. Although I was aware that this issue affected many Toyota/Lexus products from this era, I had no idea this car suffered from it until I parked it in the sun on my second or third day of ownership. I contemplated returning it under AutoNation's 250-mile, 5-day return policy, but since the car is so clean otherwise, I decided to keep it.
I'm currently waiting for the glove compartment and center console to arrive. Although not photographed, I already have the driver knee bolster. I'm happy to report that I didn't break any clips or connectors during the disassembly. It's actually a pretty simple job.
Old Mar 18, 2026 | 04:21 AM
DJJD's Avatar
DJJD
The new dash, driver knee bolster, glove compartment, and center console are installed. The reassembly went smoothly. I'll take more photographs soon.
Old Mar 19, 2026 | 10:21 AM
theryanking's Avatar
theryanking
Active Streak: 30 Days
Cool
Niceee! I bought an 08 with 96k in 2024. Same colors in and out. Mine is much more base model, however, and not as clean. I have only debadged the rear, threw a 15 inch sub in trunk, and chopped mufflers due to corroded through. Wish mine had those rims at least.
Old Mar 19, 2026 | 10:35 AM
LatinLS430's Avatar
LatinLS430
Looks really clean! Which dealership did you get it from?
Old Mar 19, 2026 | 07:50 PM
DJJD's Avatar
DJJD
AutoNation Nissan Tempe. Found it while browsing the internet. Photographs are often deceiving, but this car checked out in person. It was registered in Maryland until 2018.
Clean indeed. The carpeting was not extracted or otherwise cleaned by the dealer. This is how the driver footwell looked when I purchased it.
Old Mar 20, 2026 | 06:12 AM
Leadfoot6's Avatar
Leadfoot6
Thank you for taking the time to document and post your progress.
Normally, I would not consider this color combination, but in this instance I am very impressed with how it looks.
Old Mar 23, 2026 | 07:20 PM
DJJD's Avatar
DJJD
Thread has been updated above to include my current progress.
Old Mar 24, 2026 | 10:05 AM
theryanking
It is a nice way to get extra accustomed to an automobile. Strip parts of it down and put back together.
Old Apr 5, 2026 | 09:36 AM
DJJD's Avatar
DJJD
Current project: replacing the spark plugs, spark plug tube gaskets, and driver side valve cover gasket (it was seeping along the bottom edge). I would have completed the job in one day, but I ordered the wrong gasket. Given the unintended delay, I decided to also order and replace the PCV ventilation hoses---they've been subjected to 20 years of heat cycles and have seen better days.
This car has zero maintenance history on CARFAX or BADVIN. I can only assume the prior owner performed his own maintenance or took the vehicle to a local shop that doesn't report service information. Regardless, the vehicle has unquestionably been well-maintained, as evidenced by the valvetrain.
Old Apr 13, 2026 | 03:51 AM
THEunderPSI's Avatar
THEunderPSI
Wow that thing looks great inside and out. I wouldn't sweat the lack of service history given how well it's been maintained cosmetically.
Old Apr 14, 2026 | 08:54 PM
DJJD's Avatar
DJJD
Thank you. I agree---it's not often that a vehicle is cosmetically well-maintained but mechanically neglected.
Old Apr 14, 2026 | 08:58 PM
DJJD's Avatar
DJJD
Car is finally back together as of last weekend. While I had uninhibited access to them, I replaced the ventilation hoses. I also cleaned the throttle body and MAF sensors. Car runs great.
Old Apr 20, 2026 | 09:11 PM
DJJD's Avatar
DJJD
Few interior photographs.
