FL FS H&R wheel Spacers
SOLD! Please close
No rubbing at all even with passengers in the rear.
Availability
Are these still available? And what where your reason(s) --for removing them? I'm not worried about rubbing, more so tire wear, and handling or ride comfort? I go through a set of tires yearly I don't need to speed this process! Thanks for your time.
The reason why i removed them .
With the RSR down springs and spacers everything was in the green after alignment except for the camber at all 4 wheels which is due to being lowered and causes slight abnormal inner tire wear. A set of tires still would last me over 20k once i go with a higher treadwear like 320. You dont need to shave the stock studs since the spacers have enough width to cover them.
sleepybobcat
RX - 1st Gen (1999-2003)
20
09-26-03 04:03 AM
