Would IS350 Calipers and rotors work on SC300?
Old 07-15-15, 11:03 AM
Deegee
Deegee's Avatar
Default Would IS350 Calipers and rotors work on SC300?
I have a set of IS350 big brake calipers (oem) and rotors (front), would these work on the SC300?
I see a ton of people using the LS400 brakes but they look fairly small compared to the IS350 oem brake calipers.
Old 07-15-15, 11:16 AM
Sweatshop
Sweatshop's Avatar
This is actually a brilliant question. Supra brakes original finish doesn't hold up well to dust and heat at all. In for an answer
Old 07-15-15, 11:24 AM
Tabaka
Tabaka's Avatar
The newer IS350 front calipers look massive compared to the LS brakes.
Old 07-15-15, 11:37 AM
GISguy
GISguy's Avatar
https://www.clublexus.com/forums/sus...300-sc400.html
Someone mentioned this before apparently. I'd love to see it.
Old 07-15-15, 12:34 PM
Deegee
Deegee's Avatar
Well damn, I may need to take mine off my IS and test them on the front of the SC. Problem is... I haven't received my SC yet...
Pic for reference on my IS (2007)
Old 07-15-15, 12:43 PM
3L4jzz31
3L4jzz31's Avatar
subbed for results
Old 07-15-15, 01:15 PM
NYKnick101
NYKnick101's Avatar
After doing some research, it looks like it could work. If i remember correctly, the only thing I for see as an issue is the brake lines will be on the bottom and not the top since the SC's front brakes face the rear, and IS350 faces the front. I can foresee loose catching or breaking the line will be an issue. (i could be wrong on the placement of the brake lines, lemme go out to my car to check)
Also the IS350 rotors have 3 different offsets from the different years. 06-08 is different from 09-10, and then it changed again in 2011 to 2013 to accommodate the IS350 AWD so rotors would have to be very specific
I would say get your hand on a set of OEM 250 calipers, borrow them from a friend or autostore and then return them after and use that as your test bed because if you can get those to work then you can definitely get the 350's to work. Custom brackets can always be created, I've seen people do them for corvette calipers.
Edit: They are dead center so ignore first part!
Old 07-15-15, 03:22 PM
czar07
czar07's Avatar
Do the IS-F brakes fit IS350 without modification? Because the IS-F brake calipers are bolt on to the SC chassis
EDIT: IS-F rotors bolt on, calipers MAY bolt on, but no evidence has been found
Old 07-15-15, 06:24 PM
Blkexcoupe
Blkexcoupe's Avatar
The IS350 requires swapping the front hub from the IS-F to work If I remember correctly.
Are you sure the IS-F caliper and rotors bolt up directly to the SC knuckle? or are you saying the IS-F caliper can just bolt up to a SC knuckle?
I know when people do the Z06 calipers they use IS-F rotors and require a mounting bracket to space out the corvette caliper. I'd imagine an IS-F caliper would need the same amount of spacing.
Old 07-16-15, 01:06 PM
czar07
czar07's Avatar
I am 75% sure that someone on this forum did full IS-F brakes (calipers and rotors) onto an SC. Ill will search and get back to you
EDIT: Cant find any info relating to the calipers bolting on..someone with an SC and IS-F may need to do a little experiment for us
Old 07-16-15, 01:17 PM
czar07
czar07's Avatar
Also
https://www.clublexus.com/forums/sus...n-your-sc.html
Old 07-16-15, 02:24 PM
Deegee
Deegee's Avatar
Thanks for sharing, it appears some minor customization is needed.
Old 06-12-22, 03:30 PM
nickboi
1st Gear
nickboi's Avatar
Default Just got an sc300
I just got an sc300 and i have is350 brembo front brakes from a 2010 ill let yall know what rotors work best with it.
Carolo4554
Suspension and Brakes
06-25-20 07:06 PM
jyeung12
15
08-06-14 10:03 AM
amiehe
18
04-12-11 04:55 PM
MashinA
02-14-11 08:22 PM
drft_n_sc
04-01-08 11:11 PM
Quick Reply: Would IS350 Calipers and rotors work on SC300?
