1993-1994 ls400 y pipe
The entire Y-pipe, and catalytic converter mating flanges are toast.
Looking for aftermarket supplier of the following,
1.) Y-pipe with correct mating flanges that will work with OEM gaskets and;
2.) Catalytic converter "test pipes"; or alternatively
3.) Supplier of correct mating flanges for exhaust manifold (if not replacing catalytic converter ) and flange set between exhaust manifold for producing fabricated y pipe assembly
Find a good exhaust shop and take the old parts there for a pattern, my brother had good luck doing that with one of his cars. I would not take the whole car unless you don't care about all the banging around on the underside they would do trying to fit it.
Anyone know who offers this part or if drawing. available .. I think I located on Lextreme...
http://www.lextreme.com/allgo.html
Clicking on the image provides:
"Not Found
The requested URL /flange.html was not found on this server.Additionally, a 404 Not Found error was encountered while..."
Does anyone have current contact info for Lextreme?
Someone has a drawing...
http://www.lextreme.com/forums/showthread.php?t=8315
Attached is drawing as "CAT.dwg" file.
The link also provides ".DXF" version.
Does anyone have software to open then convert to .PDF.?
Thanks.
Are the 95-00 models the same as earlier models? I have a Y-pipe I removed due my factory one hitting some road debris at some point in its life. Luckily i found a salvage guy that didn't use the jaws of life on his and was able to use that in my car.
Do you need one? I have a factory OEM Lexus one available, but it has a gash in one of the tubes, right before the merging to the 1 pipe. The cat is intact and still good and flanges are rust free since mine is an AZ car, it came right off with hand tools. PM me if you're interested.
