Lexotic Concepts A Reflection of Perfection.
GTE Head Rebuild
Old Mar 31, 2007 | 11:29 AM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
Default GTE Head Rebuild
Removed all seals and gaskets, valvetrain and freeze plugs.
Hot tanked, replaced freeze plugs, and ready for rebuild. Got my **** and rets and other needed hardware.
I just have to clean my valves and lap them back into the head. Hoping to have complete motor built by next weekend.
Old Mar 31, 2007 | 04:52 PM
GGPIS3's Avatar
GGPIS3
sweet bro! will it bolt up to your ge bottom w/o modification?
Old Mar 31, 2007 | 06:36 PM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
hahaha it will, but since I already got a complete GTE motor, I'll just be using that and I will pull current boost ready motor and sell that as is. with 3500 rebuilt miles on it.
Old Apr 1, 2007 | 01:22 PM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
Before and After Shot of exhaust valves. I have enver seen barnicles on a valve before. I cleaned them off and wetsanded most of the carbon deposits off the valves.
I popped each vavle in my drill to check for bends and used it as a lathe to wetsand the carbon off the valves.
I dremelled polished off all other nasty things from the valves. and clean them in some gasoline.
Installing the Crower Titanium Springs and Retainers. I got a few intake valves done.
Old Apr 2, 2007 | 11:33 AM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
Well I finally got the head assembled after hand lapping the valves to seat them. I am just waiting on 3 more intake stem seals from Elmhurst Toyota and I will be done with this rebuild. My shoulder hurts from using the valve tool LOL damn 24valve motor!!!!!
Old Apr 2, 2007 | 12:03 PM
GGPIS3's Avatar
GGPIS3
hahha... awesome bro! when do you expect to have it running again?
Old Apr 2, 2007 | 12:06 PM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
Well, the supra is still running. This is a extra GTE motor im building in to swap into the car. I gotta clean and rebuild the bottom end then put it all together. once I have that stuff figured out... I will pull the engine and do the swap in a weekend. I still need a good clutch to throw in there. when I pull everything apart. Im going SouthBend DXD.
Old Apr 2, 2007 | 12:55 PM
GGPIS3's Avatar
GGPIS3
southbend dxd??? what that? btw, have you looked into spec clutches? they are relatively inexpensive and from what i hear, not a bad choice based on price. kind of like the kuhmo of clutches. they can build it to your liking too.
Old Apr 3, 2007 | 06:04 AM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
Well, I just need a clutch disk and a pilot bearing. Everything else can be reused. I am looking for a disk for under $300 shipped that gonan hold about 600rwhp.
Old Apr 22, 2007 | 08:52 AM
twojayzee's Avatar
twojayzee
Man whats with everyone thinking this is a ge build ? are you guys not reading.
B.Diddy- did you grind the valve seats at all ?
Im wondering if I should reuse the old valves on the head or replace then w/o machine work to the seats ?
Old Apr 22, 2007 | 09:28 AM
GGPIS3's Avatar
GGPIS3
^^^^ if you knew rich like i do, then you would know that he probably has 2-3 motors lying around is garage. he's changed his mind and set-up so many times its hard to keep track. between motors, bodykits...wheels... i think rich has probably had almost every quality part out there. lol
btw rich... anything goin on this weekend? i'll be in the city from the 27th-29th for my nephew's 100 day birthday. (korean tradition)
if i have some free time.. i'll hit u up.. but i'll be in the city, so ionno if you're gonna want to come pick me and naomi up...
Old Apr 22, 2007 | 05:05 PM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
ohh lol i just text'd you thinkin you were here Nah... I been too busy workin on projects to go out. We could go out to dinner or do something next weekend if you are up to it. just give me a call by thurs.
twojayzee.... I didnt have to clean the valve seats too much as they were pretty clean. I used a little lapping paste and hand lapped the valves into place. I would reuse the old valves as they are pretty strong.
CallmeQ
GS - 1st Gen (1993-1997)
Feb 17, 2013 04:34 PM
NguyenOWE
SC400 / 300 Classifieds
17
Feb 15, 2010 06:40 AM
SC400Dude
Dec 15, 2008 09:24 PM
adamgamz
Performance
Jun 9, 2008 04:54 AM
jbiel
Dec 27, 2005 05:25 PM
