GS - 1st Gen (1993-1997) Discussion about the first generation GS300
squeak from HELL!!!
Old Dec 4, 2006 | 01:01 PM
wickedst's Avatar
wickedst
Angry squeak from HELL!!!
my gs recently started squeaking when my A/C was on itermitantly. then when it started cold the drive belt would sqeak. So here is were im at now:
new drive belt: $20
new A/C compressor: $800
new Powersteering pump:$260
new belt tensioner: $180
$1500 later and still the same dam squeak on cold start up, hard turns, and accleration with the A/C. tell me im not the only 95 GS with this problem. im at the piont of getting ready to let this thing go. any experiance you guys got with this problem i cant wait to here.
thanks in advance.
Old Dec 4, 2006 | 01:03 PM
UberNoob's Avatar
UberNoob
does the rate of squeak change with the fan speed?
Old Dec 4, 2006 | 01:16 PM
wickedst's Avatar
wickedst
nope. only when theres pressure on the belt from the powerstering or A/C.
Old Dec 4, 2006 | 01:29 PM
Xeeeeeem's Avatar
Xeeeeeem
Does it do this consistanly or only when the car is cold?
Take a look at your accesory belt tensioner and the pulley. Thats what did it for me
Old Dec 4, 2006 | 01:32 PM
wickedst's Avatar
wickedst
for a few seconds on start up if its cooled down.
Old Oct 4, 2010 | 01:42 PM
gulleyman's Avatar
gulleyman
Ever solve this problem? I'm just getting started on this same journey it seems...
Old Oct 4, 2010 | 02:13 PM
vtec-this's Avatar
vtec-this
i would put money on it that its the crank pully being separated at the rubber in the middle .... best way to diagnose this would be turn the wheel and give the motor a quick rev at the same time with the a/c on and if it squeals most likely its that
Old Oct 4, 2010 | 02:28 PM
1stGS30's Avatar
1stGS30
Yeah check crank pully for cracks in the rubber on the sides might be coming apart
Old Oct 4, 2010 | 02:36 PM
rapollon's Avatar
rapollon
2nd on the crank pulley, if you put load on the system (turn on the ac), you might see the pulley wobble. change it anyway, just due to the age. Ebay as some solid pulleys. I did a refub on my car.
Old Oct 4, 2010 | 05:17 PM
gulleyman's Avatar
gulleyman
Umm...can anybody post a pic of this pulley, I'm kinda new at this...thanks.
Old Oct 4, 2010 | 09:39 PM
1stGS30's Avatar
1stGS30
this should be a sticky that way every newb can see it but IDK why they dont stick important ish like this!!!
https://www.clublexus.com/forums/gs-...y-warning.html
Old Oct 5, 2010 | 06:53 AM
jtamulis's Avatar
jtamulis
I had the same thing happen to me twice. It's the crank pulley.
Get yourself a new one, or an ATI one, or a fluiddampner.
Shoot me a PM and I'll get you one at a discount.
Jeff
Old Oct 14, 2010 | 06:34 AM
gulleyman's Avatar
gulleyman
Originally Posted by vtec-this
i would put money on it that its the crank pully...
Ya ummm, definitely the crank pulley....fell off last week Looks like I have a new project...
Old Oct 14, 2010 | 07:40 AM
jtamulis's Avatar
jtamulis
PMs sent about crank pulleys, stock VS ATI. I recommend the ATI. and It's not that bad to swap out. READ THE DIRECTIONS WITH THE ATI 8-). It's nearly a pres-fit, but it makes the engine much smoother than stock.
Jeff
cardboy008
GX - 1st Gen (2003-2009)
Jan 18, 2017 09:32 AM
BROKERIN
RX - 1st Gen (1999-2003)
19
Sep 24, 2012 12:50 PM
kez
Jul 24, 2010 06:41 PM
DASHOCKER
Performance
18
Jul 8, 2009 05:42 AM
DASHOCKER
Performance
35
Jan 23, 2008 12:52 PM
