Need some help, passenger side rod has snapped (Pics)
Old 08-24-11, 07:32 AM
edmondt
edmondt's Avatar
Default Need some help, passenger side rod has snapped (Pics)
Took my car in to service, synthetic oil change, transmission oil changed, differential oil changed...
I went under and checked to see if everything is ok, turns out this thing has rotted away to the point you can rip it right out:
Can someone help me identify this part? Is there any upgrades I can do like a sway bar for both sides of something?
Exhaust has been rusted pretty good too, I think I need new gasket cos it must be leaking... Very tempted to get new exhaust:
This picture is for the DIY Fog Light install I posted here:
Attached Thumbnails Need some help, passenger side rod has snapped (Pics)-img_20110819_141737.jpg   Need some help, passenger side rod has snapped (Pics)-img_20110818_140049.jpg   Need some help, passenger side rod has snapped (Pics)-img_20110818_140058.jpg   Need some help, passenger side rod has snapped (Pics)-img_20110818_141718.jpg
Old 08-24-11, 07:59 AM
VVTiBob
VVTiBob's Avatar
The first photos are of the one of the eight body braces. It's front "rear" brace vs front brace (passenger side) ... part costs about $40. They are there to improve the torsional rigidity of the body. The part number is 52257-24010.
Attached Thumbnails Need some help, passenger side rod has snapped (Pics)-brace-view.png   Need some help, passenger side rod has snapped (Pics)-brace.jpg
Old 08-24-11, 08:08 AM
VVTiBob
VVTiBob's Avatar
You're probably right about the exhaust gasket....a $4 part but I doubt they'll get it apart without having to cut the bolts. If they damage to exhaust pipe assembly it gets real expensive to replace those parts.
Old 08-24-11, 12:15 PM
edmondt
edmondt's Avatar
Thanks VVTiBob~!
Question: Is there any aftermarket improved parts for this?
Old 08-24-11, 12:26 PM
redliner8
redliner8's Avatar
blitz makes a bolt-on exhaust, a couple people have them on here. i recommend something custom.
daizen makes sway bars, but I dont think that's your sway bar that's rotted
Old 08-24-11, 12:40 PM
Poqman
Poqman's Avatar
edmondt, what environment does your SC operate in? Mine is an '02 and not a speck of rust on the underside.
Old 08-24-11, 03:17 PM
mandyfig
mandyfig's Avatar
That's severe corrosion. Bad.
Old 08-24-11, 05:00 PM
VVTiBob
VVTiBob's Avatar
These are braces for the body, not sway bars.... I doubt there is any aftermarket other than a shop to custom fabricate them.
Old 08-24-11, 06:35 PM
edmondt
edmondt's Avatar
I'm in Toronto Canada... I bought this SC not too long ago, its an 02 and I think I got a pretty good deal
The body is in pretty good shape, underneath is a different story with the salt and grime during winter.
Old 08-24-11, 06:39 PM
edmondt
edmondt's Avatar
I guess I will just be buying the passenger front brace (52257-24010). The car shakes when I hit the brakes, I know the alignment has been done, new brakes were installed, I just hope that the rotors are not warped.
Old 08-24-11, 07:21 PM
robertrios
robertrios's Avatar
my front rotors were warped on my IS...so expensive wish i woulda done the brakes ahead of time...ive learned my lesson
Old 08-24-11, 07:59 PM
jzwu
jzwu's Avatar
Go to a shop to get the rotors turned. Cost me $120 and the shaking when braking is gone.
Lexus rotors are thick and can be turned a few times.
Old 08-26-11, 08:25 PM
edmondt
edmondt's Avatar
I found these... They look pretty intense
http://www.l-tunedparts.com/product/?id=362
Anyone have these on? It's pretty expensive
FreshIS
02-25-20 02:20 PM
Tallgeese
06-19-19 02:27 PM
96732IS350
01-18-12 11:24 AM
bmwboyee
RX - 1st Gen (1999-2003)
06-25-11 07:46 AM
imherenow
10-27-06 02:40 PM
Quick Reply: Need some help, passenger side rod has snapped (Pics)
