car dies when going into neutral from gear
it seems like it does it in 3rd through 6th mostly.
I think basically when I shift between gears if I dont get into another gear before the tach drops it dies.
what could be the cause of this, it never wanted to die as an automatic, SC400.
has no one ever had this issue when swapping to a manual in a 1UZ?
by throttle body you mean turn the idle screw up or something? when it doesnt die sometimes it idles at like 400
mass air flow sensor more or less, but i'm no mechanic..... i don't even play one on tv
refer: http://www.lextreme.com/forums/showthread.php?t=5860
I took off the egr and cleaned behind it,aswell as raising the idle and the shifting issues gone.
modthispny
03-29-13 05:31 PM
