So I ordered the bezel, and finally found the time to do the shift mod...works pretty well, just had to break the black plastic spring support and fit a washer under the tensioner.
what right up did you use? or did you just wing it? i've been thinking about doing it as well..
Was gonna use a write up but just ended up winging it. It's really not that bad.
Originally Posted by 718murdoc
Same here bro...
Did you have to cut into the metal shaft to attach the shifter ?
I thought they didn't make these shifters anymore.
Um, I got the shifter off an auction site, just put in carbon fiber shift **** automatic. I ended up just breaking the black tensioner and replacing it with a washer...then took an angle grinder (over kill) haha and trimmed the bottom of the actual **** about an inch and a half rather than cut the metal bracket on the car.
and i just taped up and tucked the power, o/d and traction control into the console. When I get more time i'm going to relocate them all to a toggle switch.
