SC- 1st Gen (1992-2000)
Creaking Clutch Noise
Old 11-17-09, 10:52 AM
ArodDaLob
ArodDaLob's Avatar
it's nothing bad. My 15 yr old sc and 4 yr old tC both make the creak. I just think of it as something that tells other people that i have 3 pedals.
Old 11-17-09, 10:59 AM
snook
snook's Avatar
wow nobody cares to solve this, they actually prefer the creek
Old 11-18-09, 12:59 PM
snook
snook's Avatar
anyone care to solve this
Old 11-19-09, 09:48 AM
snook
snook's Avatar
any absolute comments and not just guesses as to what the noise is and the fix?
Old 11-19-09, 03:03 PM
Myblacksc
Myblacksc's Avatar
^^ someone said it in the previous posts.
Old 11-19-09, 06:35 PM
snook
snook's Avatar
nothings been confirmed from my comprehension
Old 11-19-09, 07:46 PM
Ali SC3
Ali SC3's Avatar
well if it helps i can tell you what it isnt.
I had the noise with the original clutch, then after going na-t i installed an act 6 puck clutch and pressure plate kit, resurfaced flywheel with brand new throwout bearing and rear main seal.
The noise did not change one bit. nor did any of this affect the whirring noise my w58 also has, but that is definitely an internal transmission problem.
Its just so inconsistent its hard to tell. fork.. bearings.. not bad guesses but theres not much confirmed.
Old 11-21-09, 03:45 PM
snook
snook's Avatar
Ive never had so many creaks and rattles on a car before
Actually ive never had any creaks or rattles on a car, there are so many here I dont know whats what and where to start troubleshooting since some are intermittent
Old 11-21-09, 03:47 PM
snook
snook's Avatar
Can anyone say if I should try the spring on the clutch petal?
Im also sure its not 3 bucks only
Old 11-21-09, 03:51 PM
menty
menty's Avatar
Greased the hell out of the clutch fork. It was still squeaking when we gave up. A day later, its gone quiet
/mouse killed
Old 11-21-09, 10:48 PM
TecnoSmurf
TecnoSmurf's Avatar
Originally Posted by SH_JZZ30
Yeah mine does this too. I think it has to do with the clutch master cylinder rod.
does it sound like, squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak
yes thats what it is.
I adjusted the pedal to let off more on the high side rather than so close to the floor and it went away.
Old 11-26-09, 11:22 AM
snook
snook's Avatar
I like the clutch engaging lower to the floor, mine is already high enough!
there has to be a real fix for this, what causes the problem?
Old 11-26-09, 07:05 PM
RyanV
RyanV's Avatar
It's hard to diagnose these kinds of problems over the internet.
If the squeek is constant and sounds like its rotating with the motor its probably the release bearing.
If you get a squeek only when you press the clutch pedal down, and when it comes back up, its probably the master ir slave cylinder seal rubbing against the housing..you can't fix that unless you replace the master or slave which are probably perfectly fine to begin with.
Old 11-26-09, 09:03 PM
snook
snook's Avatar
Is there a measurement in the service manual about where it is supposed to start to engage from the floor? That way I can check mine maybe it's off
Salil022
Performance & Maintenance
30
05-29-14 07:04 AM
omarmest
IS - 1st Gen (2001-2005)
11-30-13 06:36 AM
93sc3005sp
07-24-08 08:42 PM
dinhnerz
07-11-07 12:53 AM
ummagawd
08-09-04 04:10 PM
Quick Reply: Creaking Clutch Noise
