Steering Column noise
Old 01-22-14, 02:30 PM
DrewGS350
DrewGS350's Avatar
Default Steering Column noise
My wife had been complaining about a rattle noise coming from the front of her 10 RX350 when she goes over bumps at about 35mph or so. Could not pinpoint the problem anyone with a similar issue?
Old 01-22-14, 05:05 PM
RXSF
Forum Moderator
RXSF's Avatar
looks like 2010-2011 steering columns have this issue. Mine happens when I turn the wheel. Of course, dealer can never replicate the issue when I bring it in. I have made a video and plan to show them.
The HS250h also suffers from similar problems and you can search in that forum. I am sure they share the same part with the issue
Old 01-22-14, 06:48 PM
chuckGS350
chuckGS350's Avatar
There is a TSB L-SB-0026-11 to address this issue.
Check if your VIN is before the production change VIN.
If yes, take it to the dealer before the basic warranty expires.
Old 01-23-14, 10:50 AM
DrewGS350
DrewGS350's Avatar
No, our VIN does not match either one. We were also outside the 50K standard manufature warranty however, we purchased a 7 year 100K warranty and it covered the cost of replaceing the entire steering column which was $3K. I have to admit I am not big on getting these extended warranties but both times I did they paid off big time. This being the second.
Old 01-23-14, 12:53 PM
05ls430nj
05ls430nj's Avatar
Same problem here, 2011 RX, I will bring it to the dealer to see anything they can do.
Old 07-03-24, 03:32 PM
fastnoypi
fastnoypi's Avatar
How do you you know if you VIN is before the production change VIN
According to the TSB for AWD it should be before 2T2BK1BA#BC088127, mine has a 2T2BK1BA#AC... pattern for VIN.
This has been annoying for quite a while on my 2010, very noticeable creaking just maneuvering in the driveway.
edit..What needs to be replaced if i missed the 50k window of the TSB?
Old 07-04-24, 05:17 AM
Clutchless
Forum Moderator
Clutchless's Avatar
Received 1,195 Likes on 1,021 Posts
The last 6 digits of the VIN are what they use to determine the production included in the TSB. You did not include that most important part in your post. If your number is within the range listed then it is included.
However you are many miles and years too late for any dealer to probably cover your vehicle under that TSB even if it was included.
A TSB is basically a revised service procedure for mechanics to follow and not really an extended warranty coverage, unless it specifically states that in the TSB, such as this one, but you are way outside its limits.
There are many threads discussing steering column noises and solutions to solve them. Just search steering + column in the search box on the right side of the main page.
For instance see these for starters.
https://www.clublexus.com/forums/rx-...or-rattle.html
​​​​​​https://www.clublexus.com/forums/rx-...-steering.html
​​​​​​https://www.clublexus.com/forums/rx-...umn-noise.html
​​​​​​https://www.clublexus.com/forums/rx-...tling-diy.html
the lof
RX - 3rd Gen (2010-2015)
12
04-19-24 07:50 AM
jfarhat87
18
12-31-20 07:28 AM
bigcory
12-18-11 07:04 PM
corpnupe85
04-16-07 01:15 PM
HB7
03-09-05 06:38 PM
Quick Reply: Steering Column noise
