Windshield Washer spray issue
On my 2011, the washer spray pattern is fine until I get over 50km/hr. once I exceed this the spray gets lower and lower until at highway speed it's a puddle of spray at the base of the windshield. On my VW Golf, I was able to pinpoint the direction of the nozzle by using a small pin, but I was told that this does not work by my dealer advisor. Does anyone else have this issue, or is my service advisor full of it?
I had the exact same question, the washer aim is "barely" high enough at low speeds, but at higher speeds it's sometimes tough to get the top of the windshield clean. I had a look at the washer nozzles. They seem snapped onto the lower edge of the hood and they have 2 tiny bumps that rest on the underside of the hood that prevent them from angling any higher. I had thought about gently filing down the two little bumps to see if I could get a bit higher aim, but it's been too cold to play lately so it remains on my "to check out on a nice day" list.
I had mine fixed today. They are not adjustable but Lexus makes 3 different models. Neutral, 2 degrees down and 2 degrees up. They will replace yours under warranty. I would have them put in the 2 degrees up one so it covers your whole windshield.
can you explain this more? how is that written on your work order part number etc? I have the same issue and this may be something they don't get too much of.
That's for the one that sprays 2 degrees up. Since its not adjustable Lexus makes 3 different parts for the washer. Seems stupid to me. Most people get the neutral one. I think it may have to do with the hood alignment. Its' the only thing that would make the washers spray in different places. Hope that helps!
http://lexus.sewellparts.com/oem-cat...X350-2011.html
This is great info, unfortunately my timing is poor, I was at my dealer last week and hadn't seen these replies. Will have to print and keep in mind for my next visit.
Did it make a noticeable difference?
