Side Mirror Failure
Old 08-17-12, 09:24 AM
mit
mit's Avatar
Default Side Mirror Failure
My 2004 RX330 Side mirror glass is showing a liquid inside similar to a waterline in an aquarium. It hinders the reflected image significantly.
I want to replace just the glass Part # A151R, but the dealer wanted $400.
Saw the following in eBay:
http://www.ebay.com/itm/04-09-Lexus-...#ht_2845wt_952
Anyone with experience?
Old 08-17-12, 01:54 PM
kiwi
kiwi's Avatar
i would stay away from that particular fix as it wont give you the same options. its just a fancy sticker.
i have the exact same problem, i will probably order a used glass peice or a whole new side mirror and rob the glass.
Old 08-17-12, 02:16 PM
mowmow
mowmow's Avatar
Just goto sewell, the price is only $271 - $355 depending on your vin # here is an example below
a lot cheaper than dealership
Old 08-17-12, 04:25 PM
Rainbird
Rainbird's Avatar
I guess you could try the eBay mirror, if it doesn't work out, you will have invested only $23.
Here are a couple more threads on broken or defective mirrors. Be aware the green liquid used inside the mirrors is destructive to your paint.
https://www.clublexus.com/forums/rx-...de-mirror.html
https://www.clublexus.com/forums/rx-...ins-paint.html
Old 08-27-12, 07:29 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Same problem I have on my passenger side. It's showing brown tint wate lining. 98% percent is brown and you can just see the clear on the top part. It's annoying when driver side is clear and passenger side is brown/tinted. Is this normal?
Old 08-28-12, 01:18 AM
atlantatan
atlantatan's Avatar
My Right Side Mirror Failure to move up or down or side to side when hit the switch could the be switch going bad or fuse.
Old 11-14-13, 01:17 AM
Sreeni
Sreeni's Avatar
Default RX 330 mirror glass
Yes there is issue with liquid.
If you want original set you can buy from ebay. it costs more like $300
For cheap repair..follow this.....
Powered mirrors contains 2 layers and there is fluid in between.
there are 2 solutions.
1. Buy convex glass from ebay or amazon and stick top of that, it costs from 20$-50$ based on quality. ( it will not be effective like heated original mirror)
2. Remove mirror case and remove front layer which is plain mirror.
When removing, cover your car with paper or cloth to avoid liquid stains on car body near to mirror.
Your mirror act like convex any no difference in view, but no auto heat option.
Old 11-14-13, 06:52 AM
stevies30
stevies30's Avatar
Can't you go to a scrap yard and just buy the glass, pop it off and take it home?
Old 11-14-13, 07:22 PM
defo
defo's Avatar
I have a driver's side mirror glass for sale, perfect condition, heated and dimming type.
Classifieds Link
lexusdog
11-29-16 04:02 PM
snnybrr
11-02-16 12:05 PM
jkutti2000
ES - 5th Gen (2007-2012)
05-05-10 08:38 PM
eroc75
07-13-09 10:10 PM
whazzzzuup
07-05-09 07:15 AM
Quick Reply: Side Mirror Failure
