Parking brake indicator dash light
Hello.
I have a 2008 RX350, purchased new, with 45K miles on it.
When pressing in the pedal of the parking brake, my foot
slipped of the pedal. The parking brake is NOT engaged, but
the dash indicator brake (red) is illuminated. Is there a "reset"
procedure for this issue.
Thanking all in advance.
Love this site.
Love this site.
Try engaging the parking brake and then release it.
Salim
Salim
I have done that repeatedly. The light still leers at me.
The brake is definitely not engaged. I fiddled around with
the pedal area and cannot detect any anomoly there.
Thank you....
Thank you....
Are you positive it is indicating the parking brake and not a low fluid level due to brake pads being low? I know it is coincidental, but it is worth checking. If the fluid is low, have your brakes inspected, just don't fill to make light go off. It is hard for me to beleive the switch for the emergency brake is acting up by your foot slipping off the peddle as the switch is activated by creating an "open" in the circuit. Meaning the button is out when the e-brake is activated. Can you set the e-btake and then look to see if the switch is damaged at all?
Yes you could be low on brake fluid.
When was the last time you replaced your pads?
Being very low on brake fluid is also not a good sign.
Anyway check it out.
The points you are stating are valid and I have checked
the fluid and pad(s) itself and the brake is in fine shape, maybe
an 8 out of 10. It doesn't appear that the "wire" is over flexed
as it connects to the pedal. That is why I am suspecting
maybe a "reset" of sorts?
there is a little switch on the emergency brake pedal that turns off the brake light when the pedal is FULLY up. Sometimes that switch breaks, or the switch position is a little misadjusted to that it is still on even though the pedal is all the way up. My dealer replaced my switch when that happened to mine.
^^ Once you eliminate the position of the pedal and the fluid level, then it is the switch that needs to be looked at. It may have been dislodged, bent, broken etc. You will have to assume the astronaut launch position and take a flash light and explore. You foot may have pulled of the connector.
Salim
Salim
Brake switches are a pain to replace. Do not know if true for our RX.
The one under discussion is the parking brake switch.
Salim
Salim
Thank you all. I will assume the position and investigate. Once I am done with
the removal of snow (12 to 18+" on top of previous 28+") I will report back.
My bad. I am still thinking of my issue, which is the brake switch.
mandyfig as far as difficulty, you concern is valid .. this one is going to be next to the side kick plate.
Salim
Salim
Cruisin101
01-23-18 01:16 PM
rws
11-12-16 10:34 PM
