Annoying Dash Rattles
Just ranting a bit... My 07 RX350 is back at the dealership having the dash removed for the 4th time. The annoying rattles coming from near the defroster vent area on the passenger side and a really obnoxious clicking sound that seems to be coming from the area near the side vent on the passenger side are have both returned again.
These dash rattles are very disappointing. The 09 loaner RX 350 the dealer gave me has the same problem and sounds as bad as my car does.
having solved several rattles in the acura line, i would recommend taking it to another dealer if possible, or requesting a different tech look at it. if this is the 4th time for the dash to be removed the guy clearly doesnt know what the heck he is doing.
Suggestions
My '04 had a very annoying rattle coming from the bottom of the A pillar on the passenger side, near the side dash vent, when I purchased it about 16 months ago. No warranty, so I was on my own. I had my wife drive it on roads that caused the rattle and I experimented by putting pressure on various areas of the dash and inserting plastic spacers in gaps to see if the rattle could be stopped. I discovered that the rattle was coming from the gap where the A pillar cover goes behind the dash. I obtained a repair manual so I could take the area apart at the rattle location. However, after reading about how easily the side air bag on the A pillar could be damaged, I decided I would try to fix the rattle without taking the car apart. I ended up cutting some color-matched rubber pieces that could be wedged into the gap and remain virtually invisible. I wedged the rubber in fairly tight as I expect the gap varies somewhat based upon the temperature. The rattle disappeared on my first attempt and has not returned. This may or may not help other owners. Dash rattles can be very challenging. I had a Mercedes with a dash rattle and I think it took about 5 visits to the dealer to get it fixed. Good luck.
Thanks Dave. Your description below is exactly the same as the clicking sound I have. My wife found that she could put pressure on the pillar cover and get it to stop. If the dealer can't fix that one, I'll try your rubber wedge method. The loaner car I have has the same problem so it must be widespread.
My 2008 RX 350 purchased in Feb 08 has developed a rattle in the passenger door. It is NOT the seat belt making noise but appears to be in the plastic molding near the window.
Does anyone know if this is still covered by the warranty? Other cars iahve had after 12 months or 12,000 miles you were out of luck.
^^ You are right, rattles are covered under the normal warranty as stated.
