changing fog light bulb on the rx330?
Old 12-07-04, 05:23 PM
HarrierAWD
HarrierAWD's Avatar
Originally posted by VEGASRX330
my lights look so much better with the HID lights, and HID like fogs, then with the HIDs and ugly stock fog bulbs..they were too contrasting, whereas now it looks a lot better. by the way, you need 9006 bulbs (which im sure u saw in the manual).
I don't know if you have ever driven in fog with white light. The light will bounce back to your eyes in the fog so you can't see jack. The halogen light or yellow fog light actually work better in foggy weather. I wish that I could turn my RX300's HID off and just leave the halogen fog lights on in such condition.
Then again, if there's no fog in your area, go with the look, not the function.
Old 12-08-04, 11:35 AM
shikbas
shikbas's Avatar
Question
i found in store 9006 bright ,they have 55 and 84 watts,which is safer to use,i mean may be the 84 will heat up and causing problems.
Old 12-08-04, 01:49 PM
HarrierAWD
HarrierAWD's Avatar
Definitely the 55-watt. The 84-watt is illegal for street use and will burn out your stock wiring.
Old 12-08-04, 04:59 PM
JFlo
JFlo's Avatar
I purchased the 9006 PIAA Extreme White for the fogs, the PIAA Wedge bulb in blue/purple, and I have a pair of new in box CATZ Galaxy White in a 9005 (recently discontinued). I have not installed any of them, but I think it will look good. My buddy put the 9005 in the stock housing of his Integra, and it looks great .... blinding to the oncomming traffic though. I know that the PIAA lights will not be a match, but I think anything would be better than the stock color, and the wedge will help a lot too. By installing the CATZ in the high beam slot, will it change the color of the DRL? Any thoughts welcome.
Old 12-08-04, 06:35 PM
JohnsRX
JohnsRX's Avatar
but how do i change the fogs on a 300??? Thank u!
Old 12-08-04, 10:59 PM
rl9905
rl9905's Avatar
I have a 2000 RX300 and i changed my low beams and fog lights to the "REAL" Hid.. 6000K Philips Ultinon. Each bulb costed like $130 each so i had 4 total (2 for low beams and 2 for fog). With the "smart" modification, it rained so hard couple days ago here in California at night. I couldnt' see anything at allll... like nothing.... so be careful.. But if there is no rain or fog, these HID's are so good. but during bad weather, no light is seen.
Old 01-04-05, 03:00 PM
2004RX330
2004RX330's Avatar
Look underneath the bumper it was covered up by plastic make it impossible to reach up and change the fog light bulb but I can see it is right there!! There is actually a hole for you to reach up but still blocked by other stuffs. Maybe mine was equipped with the headlamp washers which ends up all the extra parts underneath the bumper. Looks like the only way is to unscrew the plastic cover underneath the front bumper but looks like too much for me. Anyone have any better idea? As for the headlight bulbs its even worst, cause it was all cover up after open the hood.
Old 03-22-08, 11:33 AM
Heat00
Heat00's Avatar
question:
I have a set, from my MDX, that I want to put in my wife's Rx330. I want to change the DRL's. The manual says 9005's 55W. The set I have are MTEC's but they say 65W draw. Can I still use them? Is this going to cause a problem? Do they have to be 55w exactly?
I understand the 84W's won't work, but what about these 65W's?
Thanks!
Old 12-10-14, 12:47 PM
papasmurf2
papasmurf2's Avatar
Sorry to ask, but whats a HID bulb? what does that mean?
C-COOP
12-20-14 09:01 AM
alsilverbullet
GX - 2nd Gen (2010-2023)
05-12-10 12:53 PM
VryniceLex
03-31-07 11:52 PM
Wald GS
GS - 1st Gen (1993-1997)
11-01-05 03:55 PM
MASH835
Lighting
01-21-05 03:09 PM
Quick Reply: changing fog light bulb on the rx330?
