display info missing
seems like i saw this thread someware. when i start my car,different display items are missing. some time it is heater info or mph/mpg info.i think i saw that it could be the the battery. help please!!!!
Out of Warranty
You are correct! The first symptom of a battery failure is strange or missing readouts on the display. It seems it is extremely sensitive to undervolt conditions. Replace with a good quality 48-month battery as recommended in your owner's manual.
Originally Posted by slick20
Great!!! will do .let you know how i make out. THANKS!!!
1) Made by Johnsons Control
2) One of the most competitive prices in down
3) Has a built in handle
4) Slightly above average CCA
Super Moderator
How often are you getting this symptom where somethings appear and then they later reappear?
I have an Optima battery hooked up with a hypervoltage unit and grounding wires and about 3 times within the past year this happens. One time they came on after about 5 minutes driving (about a week ago) and then way back a few months, I had to stop the car turn it off and then on again and everything was fine.
If this has been persistent rather than sporadic, the battery is the deal there.
For battery selection, if you plan to keep your RX for the long haul, an Optima is a great investment. Otherwise, what everyone says above is correct. Johnson Controls makes a very good line of different types of batteries. Usually at Costco, you can also find the Optimas but it takes some fitting to do.
First though, let me know how often these symptoms occur and does the clock ever reset itself and/or long with radio stations and seat memory functions?
Battery need replace new one I think what cause displace not working! It may be light bulbs ran out! My RX300 D drive bulb light ran out too! Take your car local Lexus fix problems!
I don't have missing info. on my display but my display flashes, or blinks out, which happens so irregularly that it is impossible to pin down - could this be a low voltage issue - I only noticed it in the last year or so with this original battery.
this started the other day.i still have the origional oem lexus battery from 1999. gonna get a new one tomorrow.if problums still exist after i replace the battery i will keep you posted.no blinking no flashing.blue back ground still very bright. just different display info miss every time i start my car.but not all the time.only occasionaly.i hope it is the battery!!!!! no problum with clock or radio sta. just info miss.keep you posted
Super Moderator
BTW, my OEM Lexus battery said, Hecho en Mexico, and I have driven by that plant outside Monterrey where I think they are made.
Ok
I t's been over a week since i have replaced the battery.still no problms .thanks every one for your feed back. gonna tackle those dreaded spark plugs next .will let every one know how i make out .
brendam24
10-18-10 11:29 AM
