Max Water Fording Depth ?
Old 10-30-12, 06:41 PM
triplecore
triplecore's Avatar
Default Max Water Fording Depth ?
Just curious I know the RX isn't a real SUV to take off road and not, but does anyone know what's the max fording depth for those flooded city streets? I can't seem to find it in the RX's manual.
triplecore is offline
Old 10-30-12, 08:04 PM
m1964
m1964's Avatar
Ground clearance is 7.3", Lexus does NOT provide wading water level for its vehicles, LR and VW Tuareg have numbers published in their manuals-I assume RX is not meant to be in anything deeper then 8-9" for more then few seconds...
but you never klnow how deep the water is going to be until you get in there...Lets see if any one else can provide better info.
m1964 is offline
Old 10-30-12, 11:59 PM
UCSB
UCSB's Avatar
My advice; never drive into any standing water. Water depth can change unexpectedly and you can hit submerged items. Unfortunately, my son learned this lesson the hard way in a flash flood in AZ when he ran over something that punched a hole in his oil pan and ended up ruining the engine in his car all for nothing.
UCSB is offline
Old 10-31-12, 07:27 AM
tfischer
Forum Moderator
tfischer's Avatar
Ground clearance would be the number to use, as you don't want any water getting up into any engine parts. The hard part is determining how deep the water is, as all water is flat on top. "Still waters run deep."
Etc.
tfischer is offline
Old 10-31-12, 12:32 PM
dwlink
dwlink's Avatar
Similar thing happened to a coworker of mine who made a u-turn in some standing water because it was getting too deep. He ramped a small curb and he ran over what must have been an old sign post that was cut near its base. The result - an instant flat tire. Stay away from standing water!!!!
dwlink is offline
Old 10-31-12, 03:43 PM
triplecore
triplecore's Avatar
Thanks, guess 7.3 inch is the max depth or better yet try to avoid deep water all together incase of debris.
Old 10-31-12, 09:08 PM
m1964
m1964's Avatar
After the hurricane here I first watched a Murano driving through the water, and only then made it throuh myself.
If you are patient, there almost always will be some one else trying to get through...
***When I drove LR2 I did not need to watch Muranos or anything else because LR specified 20 in. wading water. The battery was under the windshield, and alternator almost on top of the engine. If only it was as reliable as Lexus...
m1964 is offline
Old 11-01-12, 06:25 AM
tfischer
Forum Moderator
tfischer's Avatar
Good plan.
When approaching standing water of an unknown depth, pull to the side and see what happens when someone with a lower threshold of boredom plows into the water. If his car washes away, bottoms out, or bursts into flame, turn around and find an alternate route.
Let's call that the Darwin theory.
tfischer is offline
gmilburn (05-20-21)
Old 11-04-12, 03:13 PM
m1964
m1964's Avatar
Originally Posted by tfischer
Good plan.
Highly unlikely to "burst into flame" in deep water...At least I have not seen one after the hurricane...the cars do not make good swimmers...
m1964 is offline
Old 12-17-17, 08:15 AM
Paul6hms
Paul6hms's Avatar
Thumbs up Wading depth
I see a lot of people trying to find the Wading depth limit for their cars. A basic rule is to search under your bonnet to find the air intake. Follow the pipe from where you would fit the air filter, to the front of the car. It's either ends at the grill of the car somewhere or they can be under the wheel arch, which is more awkward. If you find it in the grill then measure from the ground up and take off up to 12" to allow for the bow wave. And to drive at about 2/3 mph. Have fun (as & when) I've done this dozens of times up to about 12" to 18", as my air intake is about 24" up.
Hope this helps.
Paul6hms is offline
Diesel350
Automotive Care & Detailing
08-22-18 05:39 PM
changenme
RX - 1st Gen (1999-2003)
12-16-12 03:03 PM
Chris@GlimmerGlass
08-09-08 06:35 AM
Quick Reply: Max Water Fording Depth ?
