replace Schrader Valve?
Old 04-27-12, 01:49 PM
sweetboy02
sweetboy02's Avatar
Angry replace Schrader Valve?
I took my car for 50K maintenance. For some reasons, the tech tighten my Lexus logo cap to the Schrader valve (not sure what we call in English, we connect the air pump to this little unit to add air to the tire, man i feel stupid ) ) too much and i couldn't remove it without cut the cap into 2 pieces. After remove the cap now the threads on the Schrader valve messed up. Can't use the air pump anymore.
How can i replace this valve? Thanks
Old 04-27-12, 02:21 PM
dctex99
dctex99's Avatar
Default ruined valve
It is ruined; he probably used an open end wrench because the fancy Lexus ones are 5 side and overdid it. I would go back and let them know; they should at least remove, break down and replace the valve stem for you; maybe even give you a new set of Lexus covers if they are generous...they probably only get them in sets so hard to give you just one, sadly!
Old 04-27-12, 08:00 PM
DunWkg
DunWkg's Avatar
Are the valves part of tire pressure monitor system "senders" ? Don't they have to replace the whole gizmo or can just the Shrader be replaced? Sounds like a big oops to me.
k7q
12
12-30-18 05:55 PM
MoarLow
03-01-12 12:14 AM
phamxOC
02-07-11 11:38 PM
rroy
Wheels, Tires & Brakes Forum
08-16-07 11:13 AM
Christian
08-21-05 03:59 PM
Quick Reply: replace Schrader Valve?
