How to keep radio data on Nav screen
We just got a 2010 RX 350 with navi. We're trying to figure out if there is a way to keep the radio data (e.g., presets, station data, etc.) on the nav screen when we don't need to use the map. Every time we get the radio info to display on the screen, the map pops back up after a few seconds. We then have to pull the menu back up and select the "audio" button every time we want to see our list of preset radio or XM stations.
I've read through the owner's manual and did a search on this board, and I haven't seen an answer to this question. Thanks.
I have the same question but pg 318 in my 2013 nav manual doesn't address it; I found how to maintain a " split screen " between the map and radio, but Id like to view the entire radio screen at all times. Every time I attempt to scan and preset my desired radio stations, it fades to nothing. Can anyone help..... The navi manual hasn't helped yet- thanks
Another question is whether we can have the map from nav up, AND have a row somewhere that shows the station you're on/track that is playing....this would be fantastic!
Right now, I have to flip back to the audio screen while driving to see who the artist is, what the station is, etc...
The 2013 Navigation System Owner's Manual covers how to do this on page 53. (Page 53 of the printed manual is page 2 of this PDF section.)
It's a bit obscure since it requires "paging down" from the screen you initially see to get to the option page with the pertinent setting.
The sequence is:
The sequence is:
Menu, Setup, General (scroll down to 2nd page of 4), Auto Screen Change.
Select "Off" to make your Audio or Climate Control screens persist once you're on them.
It's a bit obscure since it requires "paging down" from thescreen you initially see to get to the option page with the pertinent setting.
The sequence is:
The sequence is:
you can also have both displayed at the same time... when on the nav screen, there should be an ON button, turn it on. Then there will be an option on the left side of the screen that appears, Menu something, go in there and it should be self explanatory. You can have it display other info alongside the map
ETA- this works on 2013, not sure about previous years
IS350SWFL
11-26-14 05:28 PM
dennison17
RX - 3rd Gen (2010-2015)
04-10-12 10:44 PM
ToyotaLexus
06-20-01 07:44 AM
